Hindsider85
- Joined
- Nov 24, 2025
- Messages
- 59
- Likes
- 40
I bought the Fosi V3 Mono in a complete set from Ebay and got them today.
Im using the Nubert Nuvero 70 speakers, from the venerable German audio specialist "Nubert".
I have the Hifiman Serenade with the Gold Upgrade and use it as a Pre-Amp and DAC, to feed the Fosi V3 Monos over the internal Streamer.
Im using Tidal Streaming and Audirvana as a pre-processor, for the upsampling to DSD 512 via r8Brain.
I gave the Google A.I lot of parameters and the sound I was trying to achieve. Since the Hifiman Serenade is a pure NOS R2R DAC, I knew it would be benefitial to use Audirvanas r8Brain upsampler, to achieve the best fidelity possible. My PC is a High-End system and the processing power, albeit hefty, is no issue at all.
The Google A.I gave me the settings and they differed starkly, in some areas, from my own.
And what can I say...The A.I was right from the get go and I didnt want to believe it at first.
I was always using 85% bandwidth with the Typ B - 4th order, 160 dampening and minimum phase.
It told me that I should use 90% bandwidth, Typ A - 4th order and the rest could stay the same.
And it was absolutely right.
I got a very mellow sound, without sacrificing stagewidth and fidelity of the higher end frequencies.
My settings where rolling off to early (18khz range) and the Typ B -4th order was causing background details to vanish too quickly. Like a harpe vanishing too abruptly and not slowly rolling out. And the staging was compressed, which I only realized once I used the settings the A.I provided. Suddenly it opened up, dramatically!
I know hating A.I is the new "vogue" thing for many people, but if you use it correctly it can solve many issues in your day to day life.
Surely your shouldnt take anything it says for gospel, but, given enough parameters, it can quickly and correctly give you perfectly viable information in a mere second.
Truly impressive times we are living in.
