Yes if it's active with low frequency filtering then that should avoid the issue of excessive excursion.
Yes it was obvious. The sound was distorted and weird at any volume afterwards. We had only one speaker so couldn't compare but it was obvious.Was it obvious you damaged it? How did you diagnose it?
I did hear a very brief disturbing crackle during a couple of the parts of the frequency sweep
I think this is correct. Most monitors including these JBLs have limiters, making damage from overexcursion unlikely. Do a gated frequency response sweep on each and see if they match. If they do, you should be fine.The 308P should be harder to damage than with a 94dB/0.33m sweep. After all, that is only 84.6dB/1m, which is nowhere the speaker's max output.
How did you determine that the SPL was 94dB? Could it have in fact been much louder?
Having said that, I would hope (and expect) that an active speaker with inbuilt limiters and a high-pass filter to protect the woofer from excessive excursion would not be easily damaged, even if your SPL reading was off by 10 or more dB.
If I were you, I would remeasure each speaker in the mid-field under the same conditions. If the two speakers measure similarly, neither is damaged (or both are damaged in the same way, but that would be very improbable).
Do we really want him doing distortion tests again??Yep. And a distortion sweep would be good as a diagnostic tool. Damage may not show up on the FR, but it will show up as distortion.
P.S. I got an update, I think it could have gotten missed as someone posted at the same time as I posted......this one:
https://www.audiosciencereview.com/...r-during-distortion-testing.18543/post-607238
Ok, I'm now sure I haven't damaged my speakers during the distortion testing, it's definitely something to do with poor sound in relation to position of the volume knobs on the back of speakers. I did a quick listening session this morning with speakers at the 4.5 volume mark and sound is clear as crystal with full dynamics & imaging, turning it down lower than this removes those positive aspects, more than placebo can account for I'm sure.....I can reduce volume level on my DAC and it will still sound good as long as speakers on 4.5 volume mark on back of speakers.
I've only got one day off this week, so not gonna futz around with measuring my speakers for distortion to figure out what's really going on here with the change in volume dial position of the back of my JBL 308p speakers, but I've got a week off after Christmas in a couple of weeks so I'll dedicate a little of that time to get to the bottom of this & I'll update this thread with my testing. I'm sure there's something slightly funky going on with the volume adjustment on the back of these speakers, and I'm 100% sure now I've not damaged my speakers during the distortion testing. Will update with my testing in a couple of weeks. Thanks for your inputs so far.
Wow, really, that's not good. I'll still do my testing I explained in my last post, but it's probably better after that if I just set it & forget it....excessive volume knob twiddling might be too much for the dodgy volume controls to handle!Those cheap switches are finicky as hell. I have problems with LSR305 volume knob switches where turning the knob will not change the volume. It takes about three steps before the volume jumps up to where it should be. What I have done is set these to max and adjust the vol. level calibration via software instead.
I have also performed long sweeps at 105-110dB at a distance of 1m to my Sceptre S8s many times by now — besides playing pink noise measuring peaks up to 115dB (per speaker).
wow man. I always shit my pants when going anything above listening level lol
on the other hand Amir takes hundreds of meassurement at high volume, right?
only thing that still would scare me is that it might end the life of an old driver/tweeter?
And the limiters have saved the speakers from blowing more times than I recall. The limiters will not allow anything sustained beyond a 100+ dB or so. Doesn’t matter if you up the voltage.
Dave Gunness
than I wonder why users told me in the other topic that you can damage active subwoofers by playing them too loud
