Since the JBL has a small horn to control the upper dispersion, you might like this more.
The other one has a much less controlled and uneven response, which could be annoying in the long run.
Closer to neutral seems to be the best longevity aim.
Often you get more with a higher price... But you don't always know what that 'more' is.
It could be helpful if you describe your situation in more detail... Like budget, size of room, listening distance, preferred SPL etc.
