Hi,
I wanted to get some advise on how to best optimize the sound chain given the components pictured.
The devices are: HoloAudio Spring3/Bliss KTE Stack, Carina300 and DMP-A8
I have also shown the backs of the devices.
For headphones I was all set with the HA stack with the DMP A6 . I moved from the DMP-A6 to the A8. I would like to use the I2S cable connected between the Spring3 and the A8 and have used a decent cable. I read that I may need to make some setting changes for I2S. What settings do I need to change to make this setup work?
Also, Is this the optimal way to connect them?
For the Kef Ls50 Meta, I replaced my Denon with a Peachtree Carina300. It has a built-in DAC, which I don't want to use instead of the one in the DMP A8. I have wired the DMP-A8 --> Carina300 with both SPDIF and RCA cables, as can be seen in the picture.
Which would be better? do I need to make any changes to the Carina300 or DMP A8 to optimize or are default sufficient.
If I could use these components better please let me know.
thank you so much.
thank you so much.
