How do I compare/contrast digital pressings that *maybe the same master? Help me est. a workflow, please.
Contact
I have some duplicates in my digital audio library. I need to compare and contrast the quality of each seeming (on the surface) identical file(s).
My goal is to delete the album which has the less desirable quantitative characteristics.
Some of these duplicates may be from the same master, some may be from different masters.
Some files may be from the same master but have been EQ'ed slightly different.
I am not a audio-engineer, and in my current location I do not have a speaker setup to fully hear the differences, so I need to create a more quantitative method, backed by data from the programs listed below to arrive at my decision.
So, I came up with a multi-step approach to do so.
My library is all flac, either 16 or 24bit.
I have tried to include the most important data points, while leaving out others.
I could be mistaken on some/all of these steps.
I could be mistaken on which programs to use.
Any advice on how I could improve this would be very much appreciated.
1. Use SOX in terminal to determine if the files are real 16 or 24 bit. sox filename.flac -n stats
2. Use MAAT DROffline MkII and collect the following in a .txt file:
- DR (PMF Dynamic Range).
- PLR (True Peak to Integrated Loudness Ratio).
- LRA (Loudness Range - BS.1770).
- Min. PSR (SSPM (Sample Peak Program Metering) to Short Term Loudness Ratio).
I excluded/left out the following: (are these ok to leave out?)
- Max. TPL (True Peak Level).
- Max. SPPM (Sample Peak Program Metering).
- Max. Momentary Loudness.
- Max. Short-Term Loudness Integrated Loudness (LUFS).
- RMS (Root Mean Square).
3. Use SPEK to create a spectrogram and look for any/all of the following:
- Abrupt horizontal cutoffs (looking for lossy roll off, not quiet high freq.) as well as the full frequency range for the specific sampling rate.
- Smearing: less texture in the upper mids and highs than is to be expected. Blurred high frequencies. A few clean transients may help disprove smearing.
- Artificial Boosting (exaggerated E.Q. changes). Looking for unusually strong intensity (bright colors) in the upper mids and high frequencies.
- Any band-shaped intensity spikes (aka a hot stripe around a certain frequency).
- Detail in the low end/Presence of content down to 20–50 Hz.
4. perform a comparison of the flac files md5 checksum using metaflac:
metaflac --show-md5sum file1.flac
metaflac --show-md5sum file2.flac
What do you all think?
Can you offer any suggestions to help improve my workflow?
Thank you so much for any help.
