It's not a meaningful response. Here's how this normally gors; you as a designer or engineer need to know what fire rating is required for the elevator because it impacts structure, cost, leasable area, egress paths, whatever. It's a yes or no question.Given this prompt: Per the International Building Code, an elevator shaft in a two story building needs to be constructed
How would you rate this response from GPT-4?
As an engineer or architect I can pick up the local amendments to the IBC and look it up. About 3/4 of the time the answer will be 'it depends'. It depends on a host of issues which I haven't thought about and may not have been worked through yet. The wording of the regulations may be ambiguous, and sometimes this is intentional as it gives local authorities more opportunity to get involved in the approval process.
So, you hire a code consultant who deals with fire and life safety stuff all day every day, and they accept the risk embodied by making these decisions because they know the code back to front and understand the political climate you are building in. They may have relationships with local fire chiefs and inspectors and.may understand that you may get away with X if you also do Y.
It's not that Chat Gpt is providing a dumb or inaccurate answer, it is just presuming to do the job of a code consultant. An AI language model cannot accept liability for making mistakes. That is what counts.
