How can I play flac files on my windows computer using CCA and using my iPhone as a remote?
La!$
Speakers:Audioengine A5+
DAC:Topping D50 or D50s
Audio files: 24/196, 24/192 and DSD files.
I'd like to use the DAC of my Topping device (which I haven't chosen yet) instead of the CC. I want to use the CC to stream lossless music, if possible! My source is my iPhone and Windows PC. Yes, I have WiFi network at home. Also, I heard the D50 has ESS hump. Is that true?
Thank you for the help in advance. ☺️
I'm surprised no one responded to this, and if you still need an idea to accomplish this I'll go ahead and give you one:
1. Install the following on your Windows computer:
Emby Server for Windows
And the following on your iPhone:
Emby for iOS
2. Configure the server as required - it's pretty easy.
3. Launch Emby for iOS on your iPhone, tap the Cast icon to connect to your CCA.
4. Select what you want to play and enjoy... :cool:
By the way, CCA doesn't support DSD natively, and only handles *.flac up 24/96.Therefore, you'll need to configure Emby Server to do a transcode.
A screenshot of Emby for Android running on my tablet, streaming content from Emby Server for Windows to a CCA - this very similar to what you'll see on your iPhone:
