How Can I Add EQ To Amazon Music Unlimited Played Via a Wiim Mini?
Alan B
Staffordshire, England
Hi,
I mainly listen to music on my Sennheiser HD660S headphones.
The music is sourced from a Wiim Mini, connected to a Cambridge Audio DacMagic 200M DAC & headphone amp.
The Wiim is controlled by my Android phone or my Chromebook, using either the Wiim Home App or the Amazon Music app.
I would like to use EQ to improve the performance of the headphones and was wondering if this is possible using a software EQ, or do I need to buy something like a Mini DSP Flex?
Recommendation for suitable EQ software or digital parametric EQ hardware gratefully received.
JLGF1
You are aware that the WiiM app has 10-band GEQ I presume? (with PEQ on the updates roadmap TBD)? The Amazon app also has 5-band GEQ.
Alternatively, a Qudelix 5K has PEQ and costs only 20% of what a Flex does. Mine has great SQ with Amazon UHD.
A
Alan B
Yes, but the built in equaliser is pretty course, certainly not enough to correct the frequency response of my headphones.
Thanks, I will take a look at at the Qudelix 5K, I hadn't come across that before.
