There is actually a format called DSD wide that is used in some studios: 8-bit, 2.8 MHz.I guess that's why studios use 8-bit and not 24-bit .....no, wait![]()
24 bit is just 3x 8 bitand has absolutely nothing to do with noise in DACs nor anything I wrote. That is about bit depth and quantization noise.
So ... I will ask again... what would be the 'mechanism' for a DAC reducing performance over time and where is the evidence for this phenomenon ?
Where does '8-bit' come into play here ?
Also you made a remark about 5dB difference in noise so I my answer is about noise and noise spectra and how 5dB difference could well be audible.
I did not say anything about 8bit vs 24bit nor 16 bit vs 24bit nor about quantization noise nor about DS noise shaping nor about dither nor shaping of dither.
It was about noise levels and audibility thresholds and noise spectra, about microphone recordings and noise that comes with it.
What are ladder DACs?
Everything said in just two words.Absolute Sound
Everything that is being said here could be correct. IDK. I f you believe that Robert Harley is just a paid shill then his opinion is meaningless. If, on the other hand you analyze his explanation as to why people who focus on SINAD while not wrong for those qualities are completely missing the phase errors since while the human ear only has a certain limited amount of sensitivity to SINAD in general, it has orders of magnitude greater sensitivity to phase shifts. Maybe he's just a shill as I said or maybe he is on to something.Harley gets paid bymakeinguphearing differences. How could he not hear them.
That’s just more FUD:If, on the other hand you analyze his explanation as to why people who focus on SINAD while not wrong for those qualities are completely missing the phase errors since while the human ear only has a certain limited amount of sensitivity to SINAD in general, it has orders of magnitude greater sensitivity to phase shifts.
www.audiosciencereview.com
^^^Everything that is being said here could be correct. IDK. I f you believe that Robert Harley is just a paid shill then his opinion is meaningless. <snip>
Please, I never want to offend anyone nor do I wish to be pummeled.
I can tell you that 0.1dB is extremely difficult
AI calculates that if you are listening at 10 feet, a 0.1dB increase in level occurs if you move your head about 1 3/8 inches toward the speakers.
You know what they say about opinions, don't you?It seems my opinion
Are you sure it got the calculation right, because I caught an AI stating that 3,448,620/65536 was aprox 100 a couple of weeks ago, due to a "mental slip"AI calculates that if you are listening at 10 feet, a 0.1dB increase in level occurs if you move your head about 1 3/8 inches toward the speakers.
:Are you sure it got the calculation right
In this case AI got it right.No.
But the reasoning and formulas "look right", and the answer "looks about right".
Sometimes it doesn't.
Looking forward to your posted results... and controls used.I want to test it with ABX for the FiiO KA17 vs. Hiby FC3
In the old days magazines occasionally did blind tests - amps, CD players, even speakers were compared hidden behind a screen.Everything that is being said here could be correct. IDK. I f you believe that Robert Harley is just a paid shill then his opinion is meaningless. If, on the other hand you analyze his explanation as to why people who focus on SINAD while not wrong for those qualities are completely missing the phase errors since while the human ear only has a certain limited amount of sensitivity to SINAD in general, it has orders of magnitude greater sensitivity to phase shifts. Maybe he's just a shill as I said or maybe he is on to something.
Crap, we should all run and hide now - it thinks it’s human….
