- Joined
- Apr 19, 2021
- Messages
- 506
- Likes
- 745
It's not simply that the assertions are unproven, but also that such claims are extraordinary and without necessary proof.
If you haven't had any particular reason to look into the psychoacoustics side of things, which most of us haven't, you are likely to feel like a lot of blanks get filled in when you do. The brain is a tricky beast, and plays games that good marketing and salesmen will capitalize on. We are all about subjective testing and comparisons, but only when they are controlled with enough rigor to be meaningful.
A filter on the ADC side is to reduce aliasing. Which isn't distortion exactly. Properly designed the filters at both ends let you record, transmit and reproduce the original signal that was sampled within the bandwidth you want. Filters really aren't a personal preference. Since some odd filters cause some mildly audible effects some treat them this way. Personally I think multiple filters on the DAC output is a bad idea. If you want to alter the EQ doing so with precision using EQ makes a lot more sense than messing around with various output filters.
Hallelujah! One of us!
However, you do realize, don't you, that we will hold you to a higher standard because of this? You're one of our family now. Supper is at 5:30. Be sure to wash your hands.
I don't believe you and I don't disbelieve you. (No, my name isn't Schrödinger) But until you undergo a controlled double-blind test, your assertions are unproven. And that's not to say that they won't be proven. Perhaps they will. That's the point where we investigate the "why" ... not right now.
Hi, perhaps this will help;Okay. Are you saying that you have to use a filter? Thanks for the feedback.
I prefer a filter that is close to linear, but I also know that this is not necessarily the right answer. And I know that filter preferences can change depending on sound taste. I first try using a filter that is as linear as possible, and then try other filters.
If I can turn off the filter, I turn it off. Then I choose a filter and listen. I test various cases.
I know the basic role and content of filters. Digital filters are a type of low-pass filter, and they gradually attenuate signals in the high-frequency range. They are used to reduce distortion (aliasing) according to the sampling rate in the digital signal processing process and adjust the sound quality.
I know. I know, but if I can turn off the filter, I turn it off, or if not, I use the most linear filter possible and listen first. Then I apply the filters. That's just how I usually test new products.
Filters are a matter of personal preference.
Oh, so that's why it can't be deleted. Got it. I'll be careful when I use it!
I know you guys like the measurement, but I just said the result according to my taste. Don't think it means anything. I listen to it because I have a lot of DSD sources and I like listening to DSD format more than FLAC. Whether DSD is theoretically meaningless or not, I listen to it because I like DSD better with my ears.
It's been moved. I thought I wrote it wrong. I didn't see the video. I'll watch it later.
Right. I think that your emphasis on objective results through "measurement" is a good tool for reaching a reasonable conclusion. As I mentioned in other articles, I unconditionally look at the measurement values of products that others have measured and tested.
I graduated from an engineering college, not a liberal arts major. I like measuring. I also like scientific theories. I also enjoy explaining things theoretically.
That's why I'm posting and reading your articles.
The "analog" content that I've experienced so far is the most important point that you guys talk about, such as human illusions and placebo effects, which are the brains that make illusions or can't distinguish.
However, just because I didn't physically measure it, my experience isn't necessarily meaningless. I've had various experiences, not just listening to music.
I've had more diverse experiences than you think, but these experiences aren't meaningless.
I'm talking to you guys right now to approach my experiences theoretically.
And I'm learning along the way.
I'm not just spending my time building my audio system right now, but I'm also writing diligently to learn more things that will help me objectively in my future audio experiences.
Anyway, I admit that you guys are right. That's why I'm going to buy an SMSL DAC and a Class D amplifier.
Late to this party, but just wanted to tell you I appreciate your post. I bought a Peachtree Nova300, and then stumbled upon its review on this site, which was given a poor recommendation due to the DAC's measurements. Spooked, I bought a used Topping DAC, in perfect shape, and per this site it measured excellent (highly recommended, resting in the upper side of the blue scale). Results for me? Zero, zip, nada, inaudible, and that really surprised me, as I was expecting at least "something". The money was well spent. The Topping sounds fantastic, just like the Nova300, so I'll give the Topping to my daughter to use as she rolls through her audio journey.All DACs sound different when listening tests are done sighted and not level matched.
There is nothing strange about that as the human brain is involved as 'test equipment'.
99% or more of DAC owners test sighted and not accurately level matched and consider sighted tests valid or have a warped idea of what 'blind testing is.
It's these reports and the ones BS audio magazines (paper or web) post, that enhances the notion of DACs, cables, players, decent amps sounding different making it believable and 'factual'.
Perhaps a handful of folks really puts effort in doing a valid (blind) test with statistical relevance. Those that do become 'enlightened' but will be scorned by those that don't. They will be told blind tests are flawed because (insert many reasons) or you are deaf.
It becomes more difficult (if not impossible) to discern between well designed DACs (proper filtering, freq. response and distortion level) when DAC's are level matched and one doesn't know which DAC is playing.
There may be cases it may well be that some DACs sound audibly different (to certain young and trained folks) if they measure substantially different.
With that I mean considered become audible thresholds are crossed in one or more areas.
How I deal with 'sighted' listeners ?
I encourage them (shortly) to do a proper blind test and when interested will give some pointers to test a bit more rigid (but not court style proof delivering).
Sometimes I tell them I can't tell the difference or give an explanation (depends on the person across you).
NEVER tell them they can't or don't hear a difference because the heard so is true, You can't fool their ears after all.
The vast majority thinks I am nuts, an ignorant EE, hardcore objective idiot, deaf or have no idea how music should sound and continues to ignore the message.
They CLEARLY and UNMISTAKABLY heard it and thus it is real.... how could it not be.
Then I go on ignore on the web and when meeting face to face will 'nod' kindly and listen to their babbles (like they do to mine) and friendly part ways.
The only way to get another camp to 'think' a bit more is show them in a test. Have done that in the past (with cables) and the fun part is that they admit 'grudgingly' that they can't hear a difference but the vast majority thinks it was only in a 'rigged' test and don't change their minds one little bit.
These folks exist.. let them live their lives and you yours.
You can't easily convert someone's religion, best to just let them go on thinking their hearing is 'superior' and there are things 'we' cannot measure (yet) or don't know how to measure.
Here we are talking about relatively recent DACs, but I wonder how many people would succeed in a blind test between different generations of CD players, like those with no oversampling vs. 8X and even between the old 14 bits vs. 16 bits one. If no one is able to hear the difference that would mean that all the manufacturers would have invented these refinements only to silence audiophiles ? They are refinements that bring nothing more than a supposed improvement in sound.
More likely than lying, though that happens too, is using a very poor methodology. If levels are not carefully matched, then the test is useless. Notice how almost none worry about this. Precisely matched is what is needed too, not matched by ear. If you really want results worth paying attention to then you need blinding. Without those any comments by people are not worth the time to read or watch.Here we are talking about relatively recent DACs, but I wonder how many people would succeed in a blind test between different generations of CD players, like those with no oversampling vs. 8X and even between the old 14 bits vs. 16 bits one. If no one is able to hear the difference that would mean that all the manufacturers would have invented these refinements only to silence audiophiles ? They are refinements that bring nothing more than a supposed improvement in sound.
When I was younger we only had access to audio magazines and I will always remember a test in a magazine that was not even dedicated to audio but still did serious tests and they had tested 20 models of 1987 CD players, 10 brands with each one a low end and a high end model, for example a Yamaha CDX-500 and a Yamaha CDX-1100 and all the participants, who ranged from simple music lovers to sound engineers and audiophiles, had identified the high end model of each brand. Later when I grew up and I had several CD players over the years, from an old Sony with no oversampling one to the most recent and dozens of PC sound cards, I wondered if the tests that I read when I was younger had been rigged because I never heard a difference between any of them.
Finally, when we read reviews of computer websites that test different sound cards, like by reviewers that are not audiophiles but that can say that this or that sound card have a particular sound, as I have already seen that an Asus Xonar DG had more mids than a Xonar DX, the 2 tested flat without effect in the same setup, would that mean that these testers are lying deliberately? I wonder for what purpose.
A combination of bad methodology (as suggested by @Blumlein 88 ) and the fact that the business model of equipment reviewers depends on a) there being differences in equipment to review, b) there being a steady supply of equipment to review, and c) there being a steady supply of advertising from equipment makers.would that mean that these testers are lying deliberately? I wonder for what purpose
Please chaps, don't forget the MUSIC in all this analysis of 'sound.'Okay. Are you saying that you have to use a filter? Thanks for the feedback.
Nobody in particularWho scared you?
