The ironyunfiltered goodness
while I like my apple juice unfiltered, after some experimenting I found I preferred the OS mode on this DAC.The irony![]()
Never heard of the Crystal edition, Google comes up empty as well.it'd be an interesting academic study to bench a K11 Crystal edition vs the K11 R2R
Fiio claim only 72dB Sinad. (THD+N = 0.025%) and it is all distortion since SNR is better than 115dBI have gotten the chance to listen to one of my favorite albums on the Fiio K11 R2R as a music DAC in my system. I'm on the first song and it's pretty great to hear the improvements / changes to the sound over my SMSL DO100 Pro, particularly in the areas of weight, texture, and listenability. One thing is for sure, the Fiio puts out a less hot signal. I can turn it up all the way to 99 and turn up the pre-amp to a full 9 o'clock on the volume. Using my DO100 Pro like this would be WAY too loud. So it's a better match for my system. I wish it had a remote control though.
Just a subjective impression, this dac seems to have a smaller soundstage and I'm wondering if this is related to the low SINAD. There is something less open about it compared to my other DAC, but it seems to do well with simpler arrangements (less complex sounding recordings.)Fiio claim only 72dB Sinad. (THD+N = 0.025%) and it is all distortion since SNR is better than 115dB
It's actually unlikely you can hear distortion at -72dB - most cannot on music, so it is quite likely what you are hearing are the result of perceptive biases.
However - even if you are hearing a real difference - it is only distortion. The opposite of HiFi (objectively by their own specs, mid Fi at best), and nothing magic.
www.fiio.com
Just..... indeed.Just a subjective impression,
Since the Fiio K11 R2R has no remote control it can't really work in my main system so I moved to my bookshelf speaker desktop setup. I was having some issues with the bass being too much and the sound not seeming natural, a problem I had with another Fiio DAC I tried that I ended up returning. Using a silver IC seemed to help. Also I'm using OS mode for a better sound (imo.)
I still perceive audible differences between my various DACs.
Which controls?Have you gone through the hassle of setting up some basic controls for your comparisons?
If not, you might want to give it a try.
I know well the formal protocol, but for example putting one 8030 and another G Three (measure the same in spinorama made by Genelec), adjusting gain and verifying levels with a mic, they sound way different in tonality, if it was subtle I would have some doubts but not at all… Not any need for blind test
In my example I used to illustrate my experience, as the attenuator was on the 8030C amp, but equally mentioned the attenuator (resistive in this case, I opened the Focusrite) of my audio interface, and have another third example I didn’t mentioned which is the Ifi Zen Signature DAC V2 (which in reality is a DAC with a volume knob, better made than the one of Focusrite judging by more stability on sound varying voltage).Not talking about testing speakers, you were talking about DACs.
Convincing yourself is easy ... convincing other ASR members is the difficult partSo as a conclusion, in my particular doubt between DAC transparency and my perceptions with my own DAC-preamps, I have solved the contradiction: I was comparing one DAC + attenuator with another DAC + another attenuator and which were also working at different levels of gain to be compared at same signal output.
The DAC were equal, the harmonics after attenuation were the difference. Finished enigma for me…
Why do you think perceptive biases can't create unsubtle differences in sound?they sound way different in tonality, if it was subtle I would have some doubts but not at all… Not any need for blind test
Convincing yourself is easy ... convincing other ASR members is the difficult part![]()
Not in this case, the issue of attenuation is perfectly known and audible, apart from the fact that is not subtle if the component is simply a resistor… high frequencies are more attenuated than lower ones, they suck tone and feel flat. Reactive ones have same issuesWhy do you think perceptive biases can't create unsubtle differences in sound?
In fact, in a world of modern electronics where differences (if they really exist at all) are going to be incredibly subtle to the point of being impossible to hear - the fact you are hearing unsubtle differences just convinces more that they are simply the results of perceptive bias etc.
Sure - you can screw it up if you get the gain staging badly wrong. But with modern electronics, you really have to work hard to make it audible - and that is noise, not distortion. This belief you have that attenuation automatically results in audible defects - is what is causing you to hear audible defects.Not in this case, the issue of attenuation is perfectly known and audible, apart from the fact that is not subtle if the component is simply a resistor… high frequencies are more attenuated than lower ones, they suck tone and feel flat. Reactive ones have same issues
Analogue attenuators are suggested by many brands as Genelec do to improve SINAD and dynamic range matching properly the DAC output with the amp input.
What they don’t mentioned is the process is not transparent, here in ASR you can read an article called “The Signal Path” or “Understanding the signal Path” where a member shows a mathematical model introducing a noise and harmonics in a three blocks system (DAC, preamp, amp) and tracking the SNR, THD and SINAD functions when varying gains on each block.
The fact that if this is audible or not relay ultimately on the proper SNR and THD of the attenuation stage, but nor Ifi nor Focusrite give information of this component.
This late is a guess, but I think is not cheap to make good attenuators, and this is the reason because low price DACs only measure SINAD at full voltage, and more priced DACs simply don’t incorporate any analogue knob on the device.
Post edit: sorry, the latest parsgraph is inconsistent: more on the side that well made DACs usually don’t have analogue attenuators. All DACs usually measure SINAD at the highest voltage, I wrote it too fast
