I will, Thanks!You'd be better off ignoring all the unsupported anecdotal claims and instead learning how to read and understand all those scary charts and graphs and measurements.
That's going to give you immunity to all the nonsense out there.
I have a very cheap basic FiiO BR13 bluetooth receiver/DAC. For the price it sounds acceptable. In any case it sounds much better than a no-name BT receiver it replaced. However, the signal on the line out is somewhat quiet. Compared to line out my DVD/SACD player, it is 12 o'clock vs. 9 o'clock on the preamp volume. It is also quieter than my old no-name BT receiver, although the difference is somewhat smaller. I guess it is a common characteristic of FiiO products.I'm on the first song and it's pretty great to hear the improvements / changes to the sound over my SMSL DO100 Pro, particularly in the areas of weight, texture, and listenability. One thing is for sure, the Fiio puts out a less hot signal.
I don't think is worth debating about this topic here. I actually enjoy this forum and the reviews it does. I just commented on your post because I really like Topping gear. Now they even moved the topic hereI have read the Matrix tests on occasion.
I have a basic audio system and I have listened to some other higher level equipment and there are notable differences.
Furthermore, my speaker boxes are homemade, assembled by me and modified and carried out tests with different configurations for both speaker positioning, enclosure design and different filters and configurations of these, all based on trial and error, and I have been able to prove over time (several years) and listening to different configurations that there is a lot of difference between one and another, both when the transducers are the same and what changes is the filter configuration and vice versa and both in coloration and transparency, sound stage and general listening quality, and not just preferences.
And now I am going to say "the phrase" "According to my perception".
I think this is summed up in a phrase we say in Spain.
" neither bald nor three wigs "
That is to say that situations for everything but that quality is noted in all circumstances "almost always".
Very grateful.I don't think is worth debating about this topic here. I actually enjoy this forum and the reviews it does. I just commented on your post because I really like Topping gear. Now they even moved the topic here. I'll avoid commenting further in this forum, since I have better things to do with my life. Saludos, Vicente!
De acuerdo.
Éste también es mi último post en este hilo.
Entiendo que los altavoces están en una categoría diferente pero no tanto, porque los filtros de frecuencia son electrónicos y al variarlos modifican el sonido que reproducen los transductores.
Os aseguro que un amplificador KIT hecho con componentes modestos, solo por el hecho de estar montado y soldado por mí, sonará peor que uno montado y soldado en una fábrica de amplificadores, aunque fuera el mismo.
También tengo anécdotas pero no van a acabar con ninguna de las dos escuelas de pensamiento.
En cualquier caso, ha sido un placer charlar educadamente en este hilo.
Again...God...when will I learn?I suspect that @Vicent forgot to use his translation app.For those who want to know what he posted, here is a translation:
Okay.
This is also my last post in this thread.
I understand that speakers are in a different category but not that much, because the frequency filters are electronic and by varying them they modify the sound reproduced by the transducers.
I assure you that a KIT amp made with modest components, just for the fact of being assembled and soldered by me, will sound worse than one assembled and soldered in an amp factory, even if it was the same.
I also have anecdotes but they are not going to kill either school of thought.
In any case, it's been a pleasure to chat politely in this thread.
Translated with DeepL.com (free version)
I would have some disagreement about the first part. Some, yes, a lot, no. Mid." knows a lot of technical stuff but not their arse from their elbow".
No need to go at all! Some do-it-yourself amp kits can be spectacularly well made with careful wiring looms, good heatsinking and general internal layout, sometimes better than some cost-conscious mass-produced products. Less well compromised payouts may well introduce measured differences, but whether you'd actually 'HEAR' the difference, I don't know - human hearing is dire compared to the animal world, yet some 'golden ears' think they're fantastic at hearing differences. Perceiving multi-sensory differences, yes, but I repeat it's not just on hearing alone.Ok.
I assure you that a KIT amplifier made with modest components, just by the fact of being assembled and soldered by me, will sound worse than one assembled and soldered in an amplifier factory, even if it were the same one.
In any case, it has been a pleasure to chat politely in this thread.
OK, but if you already read about what blind tests are for, you know that the usual 'listening' can produce 'notable differences' that aren't real.I have read the Matrix tests on occasion.
