How can DAC's have a SOUND SIGNATURE if they measure as transparent?
Status
Not open for further replies.
Ok, dumb question, but better to ask than live in ignorance.
There is a possibility that the DAC is clean in the FFT graph at 1kHz, but distorts more with 6kHz signal for example. This would be seen/measured in the multitone and wouldn't go unnoticed?
Both multitone and THD vs frequency show you the performance at 6 kHz.
The regular Eversolo A6 and A8 are streamers and DACs. They are not exclusively DACs. There is a sound difference in these two devices. If you want to believe otherwise, I’m completely fine with that but you are simplifying the audio experience and sheep on here that believe you will be missing out. All I ask is that they be open minded and their ears will thank them. It’s like those who believe that speakers that score the same on ASR sound the same. That is not the case. It’s more complex than that.
All we ask is that *you* are open minded and try that properly controlled blind test that so many have suggested.
Some of these differences he said he heard playing the two Eversolo's via a digital out and using either a Gustard or Weiss external DAC. Unless he clarifies that, then he is saying these sound different as digital sources to another DAC.
Our ears hear sounds differently. That’s all I’m saying. I’m not saying what I hear is better. It’s just different.
But here is the thing.
NONE of us have ears with infinite senstivity. NONE of us have ears with infinite bandwidth. Once the imperfections in two pieces of audio electronics are so small that, for all human ears there is neither the sensitivity nor the bandwidth to detect those imperfections, then those two devices MUST sound the same. For everyone. All of the time.
This is the situation for the vast majority of electronics on the market today. And our measurements can tell us which those are - and which few are not.
Appropriately, the "lots of people on the internet" whose sheer numbers apparently imbue their opinions with value also routinely believe there are significant audio quality differences between software audio players. I recall the author of Foobar2000 was even compelled to write some blurb about it on his site/FAQ explicitly refuting such claims about his player sounding better than competing ones.
One of the filters is down 10dB by 20khz so I rate "inadvertently selecting the wrong filter" as a fairly strong likelihood if there is a real heard difference.
Could be a difference in filters. I used default filters with both. The default for the A6 is Fast Roll-Off, Linear Phase. The default for the A8 is Short Delay, Sharp Rolloff. I no longer have the A6 so I can’t test it.
They sounded different when used only as a streamer, as well, which really surprised me. And that has no filter implementation that I know of. It was sending the signal to my DACs. I can’t tell you why but other reviewers have said the difference in power supplies and upgraded components in the A8 may be accounting for it. The difference was smaller than when the DACs were being used. The A6 is a brighter device. Whether the decreased brightness is the reason the A8 sounds more detailed with a wider and deeper soundstage and better separation, I don’t know. I just know that’s what I heard with the A8. The midrange is more pronounced with the A8 and not as bright.
Does ASR do a test of in-room response for streamers, DACs, etc like Erins Audio Corner uses? Like this photo:
That should be able to measure the difference I heard. They could use a neutral speaker like KEF LS50 Meta on all their tests… I assume the A6 had a tipped up treble or neutral and the A8 is neutral or rolls off the treble. The A6 sounded harsh on some songs and hurt my ears, especially when I turned up the volume on the A6. The A8 did not unless I turned it up really loud.
I used a UMIK mic to level match for my tests.
I agree. I believe 9 out of 10 people will hear differences between the regular A6 and A8 if they have a decent amount of experience listening to audio equipment and they have something better than Bose speakers. They don’t have to be experts, but newbies may not even know what to listen for.
It’s not in the realm of infinite sensitivity. It’s clearly audible to most.
Could be. I really noticed the difference between the A6 and A8 when it came to the treble and brightness which was around the 2khz+ mark. The difference there could have skewed my perception of the devices and made me think the A8 had a better sound signature, richer midrange, etc.
No, that's just for speakers. ASR does do the same kind of measurement for speakers, though.
Playing the DAC through a speaker would tend to obscure anything specific to the DAC, it's like taking a picture of a TV and looking at the picture, instead of just looking at the TV. The equivalent measurements are done just by measuring the output of the DAC directly.
This should REALLY surprise you. Think about it. If it's just outputting the same bits of the same song, there's no way in hell it can make anything brighter, change the soundstage, or anything of the sort, unless they secretly put a DSP stage in... which would be obvious in the measurements. Digital audio just doesn't work that way.
Just consider the possibility that you have talked yourself into hearing a difference. It has happened to more experienced listeners than you, very often.
Or possibly the level matching wasn't quite on point. It needs to be measured at the speaker / RCA terminals with a good voltmeter to eliminate that as a possible cause.
I’m blowing your mind tonight, ain’t I?! That IS what I’m saying. Using the USB out to another DAC, I noticed a sound difference. It surprised the heck out of me. I tested it even more when I heard that and I can conclusively say I heard a difference.
I would never have believed it myself until I tried it because I have been reading these forums for almost five years. How could it be I asked myself so I adjusted the decibel levels to see if it was a figment of my imagination and sure enough, each blind test had the same outcome. The A6 was picked out each time on brighter songs. On non-bright songs, it was harder to distinguish… I also had a harder time picking between the HifiRose 250 and A8. Those two sound more similar than the A6. I could live with the HFR250 but I was not a huge fan of the A6 because of the brighter sound signature.
Does ASR do a test of in-room response for streamers, DACs, etc like Erins Audio Corner uses? Like this photo: View attachment 388227That should be able to measure the difference I heard. They could use a neutral speaker like KEF LS50 Meta on all their tests… I assume the A6 had a tipped up treble or neutral and the A8 is neutral or rolls off the treble. The A6 sounded harsh on some songs and hurt my ears, especially when I turned up the volume on the A6. The A8 did not unless I turned it up really loud.
The "in-room response" for all DACs, streamers, amps, etc, that have been tested would all look like a perfectly horizontal, straight line. The differences from one DAC or streamer to another are on the order of 0.1dB. Note the scale for the speakers. 0.1dB wouldn't even show up.
Testing DAC response over speakers makes no sense. Matching with a Umik is not likely good enough. You match at the input jacks to the speaker or input jacks of the power amp. You wouldn't hear the difference between these streamers as they feed an external DAC. You write and speak just like all the uncontrolled listening reviewers and audiophiles. You've tricked yourself up without realizing it. That is about as simple as it gets.
Some of us know how hard it is to accept this. There is not going to be a brightness from the way you are describing it nor for the reasons you are guessing like the power supplies.
I just posted with a UMIK mic …and used with RoomEQ wizard.
OK, thanks. As stated countless times on this forum, that's nowhere near sufficiently precise. Not even close. You could easily be off by a full dB, maybe even more. You need to measure electronically and get levels matched within about 0.1 to 0.2dB.
I did not level match that way. I used a UMIK mic at my main listening position connected to my laptop and using Room EQ wizard. I matched the decibel levels.
Sorry, you are going to need to accept this isn't what happened. What you heard, and all yes. Was there a difference for you to hear? No. Showing whatever blinding you did had a flaw in it somewhere.
Ok, well could be as I didn’t level match the way you are all recommending. It might well be but I listened to these streamers for many hours over a few weeks and I can conclusively say the A6 with its internal DAC is brighter. Maybe there wasn’t much difference with the HFR 250 and A8. I can concede the difference there was small and could be impacted by a mismatch in levels. The A6 was significantly different sounding at different volume levels.
Status
