watchnerd
I don't think that an intra-track rip would make a difference though, as long as the needle is inside a normally spaced groove. My guess would be that the media noise on vinyl is likely well above the noise floor of the recording..
While the noise floor of LP is likely well above the noise floor of the recording on anything that is made post-WW II (not so sure about 1920s-1930s material), on most of my LPs the lead-in groove sounds noisier than the intra-track grooves by far.
I don't know if it's just the cartridge settling down, or if there is some difference in the actual cutting / stamping.
