- Joined
- May 4, 2018
- Messages
- 104
- Likes
- 892
Below is the "estimated in-room response" curve of the Dutch & Dutch 8c; I posted this in the 15c thread as well. There may be a tiny bit of dippage in the region where those vertical off-axis dips occur, but it's not much.
In contrast the woofer's 1.5 dB bump @ 400 Hz kinda sticks out like a sore thumb. So, according to this curve, THAT arguably very minor bump is of much greater audible significance than those dreadful-looking off-axis dips in the vertical response.
Hi Duke,
Thank you, that’s a fair point. You’re right to question the 400 Hz bump. During early tuning of the 8c, we saw a small dip around that frequency in our anechoic measurements and corrected it in DSP. In hindsight, we shouldn’t have, because it turned out to be caused by an anechoic chamber that apparently is not completely anechoic after all.
Erin’s NFS measurements were helpful because they showed the resulting bump clearly and independently. After that, I ran ground-plane measurements, confirmed it, and we fixed it in production soon after.
8c units with serial numbers below 2300 can have this slight bump around 400 Hz. It can be corrected with a peaking filter at 400 Hz, gain -1.3 dB, Q 4. I’ve tried it, and while the curve looks a little cleaner, I think the audible difference is probably quite small.
I agree with your broader point: this small deviation around 400 Hz may be more relevant than the dramatic-looking but narrow vertical off-axis dips, depending on how they integrate into the total radiated sound.
Martijn
