fpitas
Bad idea, unless it was for a joke.possibly with just a capacitor in each band
with Goto driversa joke
I wonder if they were banging the diaphragms against the pole pieces.with Goto drivers![]()
Nope! There were definitely first-order audiophile-grade high-pass filters there. Actually, I haven't heard the phragm hitting the phase plug even once so far.I wonder if they were banging the diaphragms against the pole pieces.
My tin ear prefers the LR4 I use. But then, I never claimed to be an audiophile.first-order audiophile-grade high-pass filters there
I once heard speakers with probably five (but no fewer than four) horn-loaded bands—possibly with just a capacitor in each band (each band operates below Fhm).
Amazing how a relatively inexpensive acoustic treatment like yours can be very beneficial to the sound of music in a room!Yes the 2" thick batts. I just cut them a slight bit over the width size with a box cutter, or large bread slicing knife and slid them in sitting on the window sill, that's it.
They've been just sitting there for over 4 years now, no problems.![]()
You do understand that EQ is vital to correct the inevitable dowward-tilting frequency response of a constant-directivity horn, right? And, that once you've corrected the on-axis response of a constant-directivity horn, you have simultaneously corrected the off-axis response as well?
To put it another way, EQ is an inevitable part of using a constant directivity horn, if sound quality is a consideration.
Well... there is one school of thought that says a top priority should be having a minimalist crossover design, and another that says a top priority should be having the off-axis response track the on-axis response. In practice, those two priorities end up being somewhat at odds with one another.
EQ is useful for changing the tonal balance, and altering the response of low order modes. But it normally sounds better if you can avoid them in the first place. My point is that in many cases, EQ-ing away something is very often not the same as completely removing the audible impact of it.
Yes I spoke prematurely based on preconceived notion and insufficient sample size. Thank you for the correction. I will be more careful in the future. I am here to learn as well as share. Thanks again. Cheers.I think your accusations towards horns are a bit unfair. As far as I can see, there are four claims here connected to horns:
1: Horns are outdated.
There are different types of horns made for different purposes. They have all sorts of different properties depending on the task they are made to fit. For hifi, you need a few properties that are kind of interconnected. One is very low HOM. Another one is freedom of resonances. Controlled dispersion is a third factor. It is easy to find a horn that is developed for an entirely different purpose, only to perform very poorly on one or more of these parameters.
2: There are good and bad dynamic qualities.
This is a very unreasonable claim. There is no way of improving dynamics. It can only be degraded, meaning you move away from the dynamic linearity of the original track. I believe you may be talking about uneven frequency response that is being mistaken for some kind of dynamic behavior.
3: Horns cause uneven response.
If you have the three parameters above under control, you do not get uneven response. It is that simple.
4: Removing the horn removes these problems.
Removing the horn usually degrades the dispersion control and increases non linear distortion. If you have a very good horn, you will not improve the frequency response or dynamic qualities by removing the horn.
You are off course entitled to having an opinion, but I think your reasoning is confusing and in some ways misleading. I suspect you simply have not yet heard a very good horn that is correctly integrated into the rest of the system.
Here are some raw measurements of a 46cm horn at 15 degree steps horizontally and vertically:
These measurements are gated, but not smoothed. It is easy to achieve a very smooth response with the tonal balance you want with this starting point, and it sounds pretty damn great.
You can EQ something if it is minimum-phase, which implies it is linear-time invariant / LTI.
... this belief system, if correct, seems to support the original posters subjective opinion that horns are "highly directional".
Please help me understand this.
Thank you.I assume this is what you're referring to, from the opening post: "... they were clearly highly directional. Unless I was right bang in the firing line on axis they had no high frequencies."
I don't doubt him at all; that is absolutely true of some horns... and not at all true of others. In other words, like so many things in speaker design, when it comes to horns the answer is often "it depends." In this case, the directional characteristics depend on the shape of the horn.
Here are three concepts that are imo useful background information.
1. If you can control what a sound wave is doing for least 1/2 of a wavelength, you can control its direction (and even down at 1/4 wavelength you can still influence its direction).
2. When a sound wave encounters a sharp discontinuity, it diffracts, or spreads out in all directions as if that discontinuity is a secondary sound source.
3. In general the longer the horn, the lower in frequency it can go.
Here is an image I cobbled together showing three different horn shapes, each representative of a different general category of horns (and it's quite possible that there are better terms for these categories; this is just me winging it):
At the risk of over-simplifying, here are descriptions of these three general categories:
1. Trumpet-style horns have long continuous curves, which start out very narrow in the throat and gradually widen at a slowly-increasing rate, until finally smoothly flaring out wide at the mouth. Trumpet-style horns tend to be fairly long relative to how wide the mouth is. Now let's look at how the directionality is narrow at high frequencies and widens as we go down in frequency: Notice how narrow the angle of the walls of the horn are way down in the throat. This is the part of the horn controlling the angular coverage of the shortest wavelengths. As the wavelengths become progressively longer, more and more of the horn's length is required to control their direction, and since the horn's walls are gradually flaring outwards, the coverage angle becomes gradually wider and wider as we go lower and lower in frequency, and then the coverage angle is pretty wide by the time the wavelengths are long enough for the wall angles near the mouth to be in play. This type of horn does indeed beam the high frequencies.
2. In prosound there is a need for wide and fairly uniform horizontal coverage so that the audience members all get enough high frequency energy for acceptable sound quality. Diffraction slots, and/or diffractive kinks in the walls of the horn, are used to broaden the coverage pattern and make it more uniform. In the example shown the diffractive features result in good pattern uniformity over about 90 degrees horizontally and maybe 40 degrees vertically. Diffraction horns can be either deep or shallow or in between, depending on the characteristics the designer wants.
3. Waveguide-style horns tend to be quite shallow compared to their lengths, so they don't go very low unless they are very large. Their wall angle transitions to the final coverage pattern very early, way down in the throat, so the high frequencies have as wide a pattern as the rest of their frequency range... in theory. In practice there is often some beaming of the high frequencies if the natural radiation pattern arising from the compression driver's exit diameter becomes narrower than the walls of the horn.
There is far more that could be said about each of these general categories, and there are other categories including "hybrids", so this is just scratching the surface.
My guess is that the opening post's description of directionality is in response to hearing a horn from the trumpet-style category.
When you come across sweeping generalities being made about horns, often the reality involves "it depends" to some extent.
What's the difference between horn and waveguide like you find for example on many JBL monitors, e.g. 708P?
Isn't it generally said that the purpose of a horn—by virtue of its design—is to increase sensitivity through acoustic efficiency, whereas a waveguide is viewed more as a means of achieving better control over the dispersion?The difference lies in the way the words are spelled.
