That's great.
I'm assuming you didn't test them all at the same time in this vertical arrangement, but one at a time, right?
What are your impressions and results?
Thx, & sorry for the slow reply.
Yeah, I don't think they would make much of a line array, all playing at the same time, lol.
I had four low-mid double 12"s to set each one on, lined up horizontally outdoors for comparisons. All sitting on some subs.
It's pretty easy to crossover and EQ them all near textbook flat with FIR, and use the same xover frequency between the CD/horn and low mids .
There really wasn't all that much difference in sound outdoors, other than the off-axis rolloffs expected due to different H-V patterns. And even there it was close because they were all about 90x60 or 60x40.
Perhaps the biggest difference pattern-wise, is the XT1464 cuts off SPL faster outside the 60 deg spec, than the XR1464C.
I guess even pattern specs have an 'order/Q' to them. (I do like the XT1464 best indoors, for helping keep energy off the walls.)
What maked the biggest difference for all imo, is simply how well the quasi-anechoic EQ is done....
which I guess just equates to how well the measurements are taken and chosen, to base corrections on.
This matters most by far ime, and can turn any of them into either a sonic delight, or a turd
