Horn Speakers - Is it me or.......
Yes, measurements matter. Yes, it's great to know if it's a visual stimuli acting on the auditory perception or if it's strictly soundwaves that are creating the perceptual difference. But perceptions are what we are after. Right?
That’s essentially my personal approach to my system.
As an example, if I took only one aspect of vinyl playback - the measurements - then I may have a good reason to avoid vinyl playback and only listen to digital playback.
But there’s a whole bunch of experiential aspects that come along with buying and playing records that factor into my enjoyment, and which play a part in the experience, and so it’s ultimately the experience I want to satisfy.
The same goes for when I buy loudspeakers.
In Audio Science mode I may be asking along with everybody else:
“What differences are audible in the signal itself?” (and what are the perceptual effects of those sound waves?)
But my real world listening criteria asks:
“Which system gives me the most convincing, satisfying experience?”
Those are related, but not identical questions.
A sighted evaluation might give a better answer to the second question, while giving a worse answer to the first.
I auditioned great measuring Revel speakers and fairly neutral but not as perfect Joseph speakers and my sighted listening experienced was very pronounced in favour of the Joseph speakers. And whatever additional sighted listening factors where involved or not, it was extremely repeatable since it was consistent in auditioning the Joseph speakers many times.
I can’t say that I wouldn’t have really enjoyed the Revel speakers (although I didn’t like their looks nearly as much as the Joseph), but I can certainly say that in terms of my regular informal listening experience I made a hugely satisfying purchase, as I continue to be thrilled with my speakers, even seven years later.
Similarly I have tried living with solid state amps driving my systems here and there over the year, and every single time I have found my system to less involving and relaxing and I would feel less compelled to sit down and listen in the sweet spot. As soon as I put my tube amp back in, it’s like the involvement shot up again, and it was hard to tear myself off my seat. I did the experiment enough times to tell me that there’s no way I’m giving up my tube amplifiers.
None of that is to say that solid state amplification “ sounds bad” because of course properly deployed it’s just neutral.
But, whatever variables that would be left out in blind testing, those variables seem to lead to “the most convincing, satisfying experience” for my personal listening pleasure. As with vinyl records, if the tube amps affect my psychology I’m happy to avail myself of that aspect.
And of course, folks here who might purchase purely on measurements - maybe without even auditioning the equipment first - often get that to work out great for them as well. Lots of ways to skin a moose.
(I’ve been very happy with some gear that I purchased purely on measurements too - my Benchmark preamp and DAC for instance).
Do be cautious about driver separation distances with Marcel horns, especially as they get larger.
Indeed I will. https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-8191317
But why would the user of this 15.5"horn https://at-horns.eu/datasheets/ATH-EXAR-400-25_datasheet.pdf apparently have no such problems with his passively crossed system? https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-8191371
If so, then no lobing or other problems using the 18.11" A460D or 20.47" A520G2 horn above my 15" midwoofer in sealed 100 liter cabinet?
That is because the vertical polars of that speaker may look like below
What frightens most people without experience of building speaker systems, measuring and listening to them, are those nulls near the crossover frequency of 850 ish Hz
To take a deeper look into how the "lobes" look like in that region, here is an illustration
The situation near the crossover frequency
So in the worst-case situation, there is a lobe width of approximately. 40 degrees from the bottom of the lobe to top.
When the listener sits 2m away on the design axis, applying some simple trigonometry reveals that there is approximately 73cm vertical "wiggle room" for the head in the up or down direction. This means that those problematic nulls are aimed at the feet of the listener and most likely at a corner of the room's ceiling.
Even if this listener, having 5foot 7inch height, stands up and walks around, there is no serious problem because of those nulls in the vertical polars (as long as he is 2m+ away from the speaker).
Therefore, any discussion of driver C2C causing problems without considering the context of listening height, listening distance, and crossover frequency is nonsensical.
All it can help with in such a case is to distract one's attention from real design problems and obsess on seemingly problematic things that do not have any real-world significance :rolleyes:
And there is more: even if listening at where the null is, it's not so obvious. Early reflections patch it in, especially the lower the xo is. Also, frequency response dips are one of least audible things, way less audible than response peaks.
I am not an authority, I cannot reassure you. I chose to raise a concern, and it is, per se, legitimate.
Other people 'reporting no issues' doesn't really mean much. There might truly be nothing audible going on, or they might be overlooking something that a more careful experiment might reveal to be less preferred.
IMHO this is one of those areas where, assuming we are not going to design and conduct careful experiments, it is wise to just try to minimise it on principle.
cheers
What's the advantage of a horn speaker? It's super narrow directivity?
I don't know if this is "a thing" for horn speakers in general, but when I visited my local HiFi store a few years ago and listened to the JBL HDI-3800, I noticed they must be susceptible to how they are set up with the toe-in. In that demo room, they were positioned almost without any toe-in at all, and what could be heard was a "double-effect" of what was supposed to be the phantom center sounds. The vocal track was coming from each of the two loudspeakers, instead of a distinct-sounding center image coming from the spot right in the middle between the speakers.
I'm sure this could have been avoided with a more precise toe-in setup, but then you lose the option of fine-tuning the treble response, which is possible with many other loudspeakers that have other types of tweeter solutions.
Again, I'm not sure the above-mentioned problem is a general horn-related problem, as I have limited experience with other horn speakers.
The main advantage of a horn loudspeaker is not primarily its extremely narrow directivity, but rather its very high efficiency. A horn acts as an acoustic impedance converter between the driver and the air, ensuring that the sound energy generated by the driver is emitted into the room much more efficiently than with a direct radiator. This has several practical consequences. Significantly less electrical power is required for a given sound pressure level, the membrane deflection remains low and distortion is reduced.
Directivity is more of an accompanying feature than the actual purpose. Horns focus sound more strongly, with the degree of focusing depending heavily on the shape, size, and frequency of the horn. Modern horn designs are often engineered to provide the most consistent dispersion possible across a wide frequency range, not necessarily a particularly narrow one. This controlled directivity can have advantages because it reduces early room reflections and increases direct sound components, which can lead to better clarity and intelligibility. However, it can also have disadvantages, such as a smaller sweet spot or greater sensitivity to placement and listening position.
In summary, the real added value of horn loudspeakers lies in their high efficiency, low distortion, and exceptional dynamics, especially at realistic levels. Directivity is a tool for controlling sound in the room, when used sensibly, it is an advantage, but not the defining feature of a horn loudspeaker.
The waveguide on your Genelecs already improves the acoustic coupling to the air. In a physical sense, it is therefore a mild form of horn but with the emphasis on dispersion control rather than maximum efficiency.
Thank you. That was so informative and concise.
Yes, exactly. You anticipated my next question about the waveguide relationship to horn. That's my frame of reference.
This is the way I use and hear my main nearfield 8361a monitors, toed in with a high direct to indirect ratio. And despite it being coaxial, I do find the sweet spot to be small. It's plenty for a single person though. The comparison is useful.
In pro audio application it is both, equally.
And in the home it is, arguably, neither. Non-horn drivers, when chosen for strong output with good quality, can achieve SPLs well above the demands of home listening, and domestic amplifiers are widely available with more than enough power to deliver those SPLs cleanly. So, there is little need for the higher efficiency. And as for "extremely narrow directivity", domestic audio science seems to point more in the opposite direction, and would give very little support to the notion.
As I explained above, electrical power is not at a premium when driving non-horn drivers, at least domestically, so this 'practical consequence' has no real consequence, in practice.
As for distortion, horns really struggle to keep distortion as low as a good non-horn, even after allowing for the power difference. Not at domestic SPLs.
Domestically, I argue that it becomes the primary/actual purpose, and the sub-class of horns meeting this functionality is called waveguides.
...and that makes them waveguides, and best discussed as such to avoid confusion.
You make it sound like horns that are not waveguides have "real added value" in the home. I don't think so, and have explained why.
[to Audionaut] Thank you. That was so informative and concise.
...You anticipated my next question about the waveguide relationship to horn. That's my frame of reference.
That relationship has been discussed earlier in this thread. (link1.... link2) There are misconceptions about the use of the terms horn and waveguide and the relationship.
I guess I am not so concise, but there was more to be said.
cheers
From what I've seen, typically the distortion is mostly or entirely second order and likely not of audible consequence.
Perhaps not when talking average power levels, but for dynamic peaks it may be different. Particularly if you aren't running 500W amps, which aren't a practical thing for everyone despite the constant refrain of "power is cheap".
I'd like to ask a "why" question for those who are knowledgeable about "horn" sound.
I just attended the Florida Audio Expo and made it a point to go to all of the rooms with horns sequentially so that I could try to remember/understand "horn" sound. They did not shout but they did give a sense of effortlessness and a sense of being a little bit closer to the musicians than most (but not all) of the other speaker types (panels, cones, etc.).
From this thread, I understand the perception of effortlessness and I'm hoping someone can explain the sensation of being closer to the performance.
It's just sensitivity. Horn makes driver more sensitive, thus it gets louder with less power, usually meaning the driver has to work less to generate high levels of sound so distortion is typically reduced.
Ktacos....the low distortion creating an effortless sound I understand....but why the sensation of the performers being closer. Maybe for horns 20 years ago this was "shouting" but none of what I heard was in your face shouting, just the sensation of being closer....and generally, the sound of horns being played on horns was pretty darn good as well.
Sounds like the impact of controlled and narrow directivity. Soundstage will make it feel like performers are in the room.
In general it’s hard to make broad generalizations, because horns are very different animals with very different acoustic behavior. Sometimes the only thing they really have in common is the bias people have against horns :)
If I had to guess what might be causing it, I’d put my 5 cents on directivity characteristics (for many commercial horn systems the directivity is narrower over a wider bandwidth, though that’s not a universal rule). Different crossover points and different phase relationships between bands can also have a noticeable impact on how the soundstage is perceived.
My perception is the opposite: with wider dispersion the perception shifts toward “the performers are in the room,” while narrower directivity tends to feel more like “you are there” or at least that performers closer to you.
oledgtern....my perception is slightly different. It is that the wider the dispersion and the more reflections, the more enveloping the sound which makes it feel like in the room...but a completely different sensation than that of the horns I heard at the show which were more of an in the room, right in front of you, less enveloping and not in the least bit harsh.
It sounds to me like we’re actually describing a very similar experience, but let me clarify my point once more.
Imagine a situation with no reflections at all, or very few of them. In that case you mainly hear what’s on the recording: the instrument or voice itself, plus the recorded room reverb. That tends to create a “you are there” impression. The voice will usually feel quite close, it was recorded close to the microphone.
Now, the opposite case, with lots of reflections in the listening room. You do get more sense of envelopment, but the acoustic signature of the recorded space is masked by the acoustic signature of the listening room. The impression shifts toward “the musicians are here,” in this room. If the speakers are placed well away from the front wall, you’ll likely also get more depth and distance to the voice (Haas effect), so the voice can feel deeper / farther away from you.
That’s also why I’d ask which specific horn models you heard at the show. They can differ enormously in their sonic behavior, or sometimes be quite similar. A horn is a horn only in name—just like a car is a car. A Fiat 500 and a Ferrari 550 are very different animals. E.g. JBL 4367 and Avantgarde Duo are also very different.
A horn / waveguide with a compression driver can be designed in very different ways. It can deliver either wide or narrow (more commonly) directivity, it can have sharp colorations and lots of diffraction, or keep those effects to a minimum. All of this has a direct impact on the listening experience.
Really!! Wow
