kyle_neuron
- Joined
- Jun 18, 2021
- Messages
- 149
- Likes
- 259
I can maybe impart some ‘user experience’ here on that topic before Tom gets in with the real scienceIt seems to me that the internal geometry (like a tall pyramid) would result in the mid and low frequency ranges having local pressure maxima at the apex, where the compression driver's diaphragm is located. Does that happen; and if so does is it of any consequence; and if so does that constrain your compression driver choices?
A few years back I went out to the Brazilian Danley dealer with a friend from the States to investigate a recurring issue with them losing HF drivers in their bigger Jericho and Synergy horns. It was also a good excuse for a working holiday but that’s another matter… anyway, at 100% import tax, losing an Italian premium HF diaphragm is a costly affair, even more so when there are four per box. I flew sixteen spares in my luggage to stock them up… The shows these guys do run 24 hours for a solid week, full blast (and I mean face meltingly loud) in the sun, wind and dust.
Anyway, one such theory was the same you suggest here. We wondered if the sheer amount of rolling 180 BPM+ low end (psychedelic trance, don’t ask!) coming off the six 15” drivers in their Jericho could be putting tons of extra stress on the diaphragms. So we tested it, with a scope attached to the otherwise unconnected and unamplified diaphragm terminals, hammering the crap out of the rest of the box. We even put the other Jericho speaker and eight subs against the mouth of the horn, and tried that. There was evidence of slight movement, but certainly nothing that would suggest the diaphragms would be forced to slam into the phase plug even when running hard.
I’m guessing the loading down the throat end is sufficiently spread out on the bigger boxes to help alleviate that, and the acoustic or physical filtering approaches the design is built around also work ‘backwards’.
Remember there are a ton of cone midrange with their own taps, and those likely spread out some of the pressure too. It’s something that could maybe benefit from a swanky COMSOL model to verify further, but the field testing seemed to answer the question for me.
Either way we resolved their issues with some adjusted DSP settings, a much more rigorous maintenance & cleaning policy, some extra scrim or mesh across the gaps, and a general guide to bring more rig for the gig - putting out delay lines at 40 metres, for example.
View attachment 168973Is that stuff for real ? i was looking at compression drivers to learn what they are about a bit more . Lots of manufacturers seem to list the power in the " testing tube "
but this is on a 40X20 horn ? how can that little driver still push 105db at 300hz with only 1W ??
Do most compression drivers have this kind of compromise ? this one seems to drop quite fast before 10khz
but goes very low for its size , most of the smaller ones drop real fast under 1KHZ but most go up to 30khz iirc
I am totally impressed by this graph .lol
It is for real, but typically the drivers don't sound so hot at 300 Hz. Not the ripple on the green trace, a sign of breakup modes. Having a driver which can do 300 Hz in the lab test condition is a good indicator that you'll get decent results to 600 Hz, for example.
A plane wave tube is a common test because it's a known construct with an analytical solution; you can more readily expand the PWT results of different drivers to a horn of your own, than test data taken on different horns with different coverage patterns and acoustic loading.
That particular BMS is the midrange version I believe. There's a variant which is the full coaxial, using two diaphragms. They're good, but there's a narrow resonance in the 'vanilla' versions which I personally find unpleasant. It can't be EQ'd out either. The later HE versions cost more cash, but massively reduce that issue.
If you're looking at high end 'pro'ring radiators, then may I also suggest the B&C DCX464 and Faital Pro HF1440? The former has exceptional mid-range performance, where the latter has the smoothest HF detail of this type - in my subjective experience. I think the Celestion Axi2050 is already known here, even if it's not really the same 'thing'. All of them benefit from a very optimised horn.
