Joseph Crowe
- Joined
- Oct 25, 2019
- Messages
- 105
- Likes
- 260
- Thread Starter
- #21
The best midrange I’ve been able to achieve is when it’s used in a large format front horn that provides controlled coverage down to 400Hz. However the horn ends up being at least 50cm wide to achieve this. The other challenge is integrating the tweeter. You can either put the tweeter in the midrange horn or you can use the NEO8 planar which covers 200Hz-20KHz all on its own.@Joseph Crowe
Is there any benefit to a horn for the 5" woofer (or a 4" one)? I thought I saw something on your website with that approach. Mainly, I was thinking it might help match dispersion to a lower frequency. But maybe lower frequencies are too omnidirectional to be affected.
