- Joined
- Apr 4, 2020
- Messages
- 46
- Likes
- 37
After several years of being without a theater, I built version 3 of my theater last summer and got the theater functional, but time constraints and budget over-runs prevented me from putting the finishing touches on like acoustical treatments, and I believe it’s time to remedy that situation. I’m looking for advice on how many panels to purchase and where to hang them.
Let’s start by telling you about my room. The room is 16’x21’x8’ with luxury vinyl plank floor over concrete. Walls are double 5/8” heavyweight drywall with rockwool insulation and the ceiling is 5/8” drywall with pink fiberglass insulation above.
The room has the screen mounted 27” away from the front wall and a “false wall” with the L/C/R and four subs behind the screen. The room has a two-row configuration with three seats in each row and the second row on a 12” riser. The surround and rear-surround speakers are in-wall speakers, and the four Atmos speakers are in-ceiling speakers. I have two layers of Linacoustic duct liner floor to ceiling behind the screen wall that wraps around the corners approximately 18”.
I have 21 Auralex Minifusers for diffusion that are currently unmounted (and unpainted!). I can use them in any configuration, but I was thinking of making a three foot tall and seven foot wide panel with them and mounting it above the rear seats on the back wall, but can use them in another configuration if it treats the room better.
My initial thoughts are in addition to the Minifusers on the rear wall to put Acoustimac absorption panels on the walls – I was thinking four – 2’x4’x2” panels on each side wall as well as a couple of 2’x4’ panels on the ceiling. I have attached a sketch of my planned layout, does that look OK or are there things that I could do to differently to increase effectiveness? Should I make any of the panels 4” bass traps rather than 2” panels? If so which ones? My OCD for symmetry says maybe the ceiling mounted panels but that might not be best.
Also, I am thinking of going with Acoustimac’s Eco-Core insulation as they say it outperforms Roxul or OC703 – Does anyone have any experience with it? Also, my room is a dark gray and I am thinking of going with black panels. Is there any advantage between any of their three fabric options (DMD, Executive, and Suede)?
Thank you so much for your help as I work through the last few touches of my Home Theater!
