Pareto Pragmatic
There is a lot of good advice here, but let me chip in on learning your room, then suggest some options for what might work.
If you have speakers with known measurements, and a neutral enough source, then any deviations from the measurements are from your room.
Three measures: pointed straight into the room on the long axis, then the shorter sideways direction, then line them up corner to corner ( as close as you can). That will give you the three major sources of room modes. Beyond that for finer detail....
If you toe the speakers out, you will get more sidewall reflections, in will give fewer. Angle them down, then up. Move them closer to walls, further away (rear ports in particular) to see what the front wall does. Changes will show up, and you can figure things out pretty well. Particularly once you know the three major axis modes.
When you do that, keep in mind the opening in the room. Pointing the speakers towards openings reduces room reflections, and making first/etc reflections point towards openings also has an effect.
You can probably learn a lot about your room without measuring and playing with the speakers, but measuring makes things a lot easier to correct.
For your room, the problem being reflections, you will likely want a narrow radiation pattern. And elevated treble? I would avoid that, but in any case I see a high shelf in your future!
Looking at the room, I would very much like to either use the opening to the photo right, OR if those windows open ....
Speakers pointed at an open wall of windows cures a lot of ills, and I would personally 100% make that happen. But it does not look like a current option.
So for me, I would try a right side placement where the chair is, speakers on either side, with the closer to the window speaker being further out from the side wall. toe them so they are angled to bounce first reflections from both speakers to the opening on the right. And I would likely lift the speakers and angle them down just a bit.
I think that would give me a single spot that was pretty good, and a room filling sound for less focused listening.
Another option is to go with some weird omnidirectional speaker, something that uses reflections to produce an effect. I have no experience, so no opinion on that option. Other than it exists. But if you have a dedicated media room, maybe? Or some weird offering from B&O with room correction? I personally would need to demo such a thing, and would never try to predict behavior from measurements on such systems. But I am no expert, just someone with a lot of room issues and time to experiment.
Beautiful room btw, really. Enjoy!
