Home office pre-vs-post acoustic treatment measurements
BrentW
When I was considering acoustically treating my office/listening room/recording room I couldn’t find a lot of “pre vs post” room reverb measurements online, so I wanted to share my data below to contribute to the collective knowledge-base.
The room:
Approximately 12x12x8ft. Hardwood floors with no rug or carpet. Walls/ceiling drywall. Main plush furniture is a big loveseat and an ottoman. There is always a lot of stuff in the office (guitars, gear, storage) but not a lot of absorptive materials. In both sets of measurements I was in the room so would contribute slightly to absorption also.
The speakers:
DIY active monitors using Adire Extremis 6.8 (anyone else remember this?!?) and a Peerless 810921 (now ScanSpeak D2608) tweeter in the dome SEOS waveguide using MiniDSP Flex for crossover. Ported box and gets down to ~50hz before rolling off. Note for anyone who tries to replicate the waveguide setup, the faceplate isn’t flat and the resulting gap created a resonance, so I used Sugru to mold a flat/smooth mating surface.
The treatment:
  • 2x GIK B4 full range 2ft x 4ft traps on the wall right behind the monitors, Guilford cloth
  • 3x 2x3 Audimute ~1.5” panels up higher on the wall behind listening area and on side wall, Guilford cloth
  • Why mix/match? The 4” B4s are pretty beefy, and the thinner panels just look better hanging on the wall up high.
  • I made sure the B4s could effectively absorb the main first destructive back-wall reflection from the monitors – otherwise would have gone for 244 (from memory I think this was ~170hz or so – around there)
  • The room is generally quite messy so I’m not going to include a photo, but the desk with monitors is against the wall and off-center to be nearer to a window. This puts the left monitor almost in a corner, so then the left B4 trap is also then in a corner. B4 traps set up to start ~6in off the ground and all 5x panels are mounted flush to wall.
Why did I do this / my expectations:
I’ve been an audio enthusiast for >25 years, building my own gear etc, but have never tried acoustic treatment. It’s a new frontier – would it do anything I could measure? Could hear? Frankly for how much I was willing to put on my walls (not much) I didn’t expect anything – was definitely primed for disappointment.
Pre vs. post measurements:
  • Measurement method:
    • Behringer ECM8000 omni measurement mic into Focusrite Scarlett 2nd gen 18I20. Mic placed at ear height at listening location (~4ft from each speaker on axis with tweeter). 8 samples used at ~80db. Single speaker used and same speaker used in pre vs post measurement (left speaker – the one in the corner). Given low noise floor of my house, this provided a lot of room for measuring decay before hitting noise floor.
    • There is a sliding glass closet – the door was closed for these measurements and the office door was always closed and the AC off.
    • I was in the room for consistency but sitting on the floor quietly away from the mic.
    • Its worth noting that EQ was applied to the speaker/resonances fixed with PEQs before listening/measuring in both cases. As far as I’m aware this EQ should not have changed the reverb measurements.
  • RT60: In general it went from 400-450ms to ~300ms from ~300hz up; Bass region a bit messier but especially in midbass much lower in treated scenario
    • “Pre” results, RT60 Topt:
    • “Post-treatment” results, RT60 Topt
  • Clarity: This one I can’t begin to say what is good or bad but here are the #s – for C50-C80 treatment seems to have increased the values 3-5db on average:
    • Pre-treatment:
    • Post-treatment:
Subjective assessment: As mentioned above, I was expecting no discernible change. To my surprise there was quite a change. It is very hard to describe – but everything seemed more “dry” (e.g. less reverb), focused (imaging more precise), and for lack of a way to describe it, precise. More headphone-like, perhaps. I know my speakers have very low distortion from measuring them, but this felt like a “different” kind of distortion was taken away. I can now more easily hear effects applied in a mix (ok I see it sounds like the track was doubled, phaser added, etc.) whereas before I would just hear the “sound” and be unable to pick it apart. A voice which before sounded like it came from a cantelope-sized space now almost seems to come from a tiny point.
So I love it right? Well…probably I’m just used to listening in reverberant and untreated spaces, but the short answer is no – I actually enjoyed listening to music more before. If I was an audio mixing professional, I 100% would prefer the treated setup as it would make hearing effects, understanding reference tracks, etc much easier. But I listen to music for fun/pleasure and it has taken some of the fun/emotional connection away.
I’m planning to leave it – I figure it may grow on me and there are other practical benefits (absorbs my loud guitar playing etc.). Would I recommend this as an experiment for learning? Yes of course if your budget allows. Would I recommend this for enjoyment/optimization especially if budget is tight? I would recommend you go listen to a good audio setup in a more professionally damped space and see if you like it.
Hopefully the above helps the community! I have a very full life (3x small kids etc.) but if there are comments or questions I will do my best to respond with delay.
Bonus: Since this is ASR here is the distortion plot and FR at ~80db 8 samples - that tweeter has some seriously low distortion!
Yeah I know, its not that flat etc etc I still like it :).
Indeed this is how most people perceive such changes. This is why I like EQ solution as you can turn it on and off instantly and adjust to taste. And not impact broadband spectrum.
The room:
The speakers:
The treatment:
You'll get used to the difference of an untreated vs treated room.
One thing I've learned over the years of plastering panels and trap everywhere is that even distribution of them is more preferable then symmetrical placement. Clumping them together can cause issues.
The best results I've gotten is having front and side walls reversed from one another -- typically in a checkboard pattern. That way, all surfaces have some treatment and you don't end up with glaring resonances from untreated surfaces.
There are some surfaces like front and side walls which do need a panel in a correct spot to eliminate a reflection, but depending on the distance...it may not be necessary.
Maybe? Luckly, I pretreated my listening room before setting my equipment, the frequency response is not perfect but quite decent and I am please how it sounds.
I see a similarity with pictures modes in TVs and projectors, no matter how many times I tried film maker mode never grew in me, I know is the most accurate one, regarding colors, is what reality is supposed to look! but no use, i tried and tried even using it only in a dark room, but the other modes always look so much better to me, I stopped fighting it and enjoy my over saturated movies.
Until something else sounds slightly off ..... Down the rabbit hole.
Thanks for sharing your experience.
Your preference mirrors my own. For what it's worth, I was used to listening in an overly treated space and then discovered the joys of a relatively lively space.
Your preference mirrors my own. For what it's worth, I was used to listening in overly treated space and then discovered the joys of a relatively lively space.
I am not a huge fan of super live sounding spaces, but I agree... a really dead room sucks the life out of the music (pardon the pun).
I think diffusion is under rated and under utilized.
Too far in either direction is less than ideal. I would wager that the trend among those trying acoustic treatments is toward too dead. Just try the calculators of some acoustic panel vendors.
My professionally designed space has around 100 sq. ft. of absorption, but an online calculator tells me I can get basic treatment with as little as 69 sq. ft., I can do better with 138 sq. ft., and sonic bliss is achieved with up to 242 sq. ft.. Yikes.
Re: Diffusion
Couldn't agree more. Overall there's nearly as much scattering and duffusion treatment in my space as there is absorption.
When I first treated my small 10x10x8 office, I also did all absorbers, and I also felt it sucked a lot of the life out of the music and sounded dry. Rather than give up and stop there, I swapped out all the rear wall treatment for a mix of 4-6" GIK Alpha panels, which offer diffusion in addition to absorption. I also put some 4" Alpha panels on my ceiling. Adding the diffusion completely changed everything! In my small office, too much absorption without some diffusion was not a good thing. Maybe try to mix it up some and get some diffusion in there.
I think the issue most people make is they overtreat the room with too many thinner panels and just end up throwing them up on the walls and ceiling where ever they happen to fit.
When I redid my office, I found that less, but significantly thicker panels produced much better results.
I also noticed that my preference curve changed with the treated room. I typically listen about 75dB. Now, I've found the bass to be good still at 75dB, but I can lower everything else from about 300hz about 5dB and it still sounds crystal clear and well balanced.
