killdozzer
I was looking allover for this exchange I had long time ago, but I still can't find it. Will you allow me to get away with some very basic mathematics you can get from an AI?Sure, file size, channel numbers, playback media capability are all big considerations.
I was looking at your post from a bit different angle, sound quality. My thought being that IMHO RedBook is totally transparent so whether 2 or 25 channels 16/44.1 would still be sufficient. But mostly since the multich boom has starting in the last decade and public perception is "HiRez is better", every multich medium I aware of is using something faster than RedBook. Which isn't a bad thing unless, like you say, file size becomes a issue. 24/48 lossless for Atmos is just fine to me, 24/96 as used for a lot of 5.1 flac file downloads now is just perfect.. Certain music labels are pushing DXD 352.8 kHz/24 or 32bit at extra cost which is just an insane waste of space & pure snake oil IMHO.
No, a standard Red Book CD cannot fit a 60-minute, lossless multichannel music program.
The Red Book standard specifically hardcodes audio format limits to uncompressed, 2-channel stereo (16-bit / 44.1 kHz). It does not support multichannel audio or data compression algorithms at the system level.
However, if you are treating the CD purely as a physical data disc (CD-ROM Mode 1 or Mode 2) to store compressed files like FLAC, the data still will not fit due to mathematical storage limits. [1]
The Mathematical Breakdown
A standard high-capacity CD holds a maximum of 700 MB to 800 MB of raw data. [1, 2, 3]
Assuming a common 5.1 surround sound layout (6 discrete audio channels) at the minimum CD quality (16-bit / 44.1 kHz), the space requirements look like this: [1, 2, 3]
- Uncompressed Multi-channel: 60 minutes of uncompressed 5.1 audio requires roughly 1.91 GB of space.
- Lossless Compressed (FLAC / WavPack): Lossless compression generally reduces file size by around 45%. Even with this compression, the file size sits around 1.05 GB.
***Even if numbers don't fit perfectly, this is my point. I do appreciate SACD for the purpose of storing multi channel lossless.
I just don't think it's SQ, it is merely there to have enough space.
