Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,271
- Likes
- 11,095
Himalayan Salt Lamps as a HiFi tweak
Apparently it's a thing now
Is Magico incompatible with salt lamps? I'd better ask over on Audiogon!Oh, he’s using Magico speakers.
Well that explains it.
I'll never understand science.They supposedly dry the air and then the sound travels faster /better
Until you touch your equipment...static shock is deadly for your equipment...They supposedly dry the air and then the sound travels faster /better
If you spent enough to get Magicos, one would hope their money went far enough to not need goofy gimmicks like salt lamps to get good sound. But maybe I'm just a cloth-eared poor person who doesn't understand how an undetectable change in humidity might drastically improve my sound. My system isn't resolving enough.If you have Magico budget, all reason is out the window.
The people here have never heard really good systems, so they might not even notice.Salt is hygroscopic. These lamps will absorb moisture in the air when not turned on. When they heat up from the bulb, they release moisture into the air.
Barbie warned us that math is hard.
If you need to do math to figure out a chunk of salt won't have major impacts on your acoustics, lack of numeracy is not your biggest problem.Barbie warned us that math is hard.
