High vs low damping factor in amps (Bass "suspension")
Does the older receiver had a "loudness" switch? That will boost the bass at lower volumes.
You beat me to it.:)
Loudness functions, tone controls and maybe Sansui au505 low pass function function turned on (although it shouldn't render in the sound AJM1981 experiences).
It's not guaranteed that tone controls that are in the 0 position don't affect FR. That can be sensitive and tricky to set.
Low damping factor (classic Sansui):
It seems to utilize more potential from the woofer of the same standmount loudspeakers.
Low damping factor of the amp inevitably also means higher inner impedance of the amp, which will cause the system´s amplitude to increasingly get dependent on changes in impedance of the speaker. The latter is by no means a constant factor, but changing wildly particularly in the lower bands with a vented box system, as well as around upper range of the midrange driver and transitional bands (as a rule of thumb). Employing an amplifier with lower damping factor, almost always constitutes higher level in the bands in which the loudspeakers impedance is spiking.
So not every perceived difference is necessarily an error and due to bias, but can also be just a kinked frequency response. Which should make one even more cautious with stating that low damping factor constitutes any particular sound.
The au505 has a loudness switch, like my entry au101. Only where the au101 user would perhaps slightly benefit from it being a nice feature (it is really subtle unlike some other amps), it could in my opinion as well have been left away on the au505. Even at low gain the au505 in its initial settings has enough presence and its loudness contours make it sound way too dark / restless for low volumes.
Okay.
Do you experience the same differences between them at low volume as well as if you turn up the volume?
Speaking of volume. What @antcollinet said in #20 undoubtedly affects the experience. Differences in volume, which is proven by The Fletcher Munson Curve:
Then we have the aspect that the loudest sound wins.
However, worn-out electronics can affect. In my closet I have parked a Luxor 5982-R. It is in the closet because the bass with it is swollen and rumbling. I don't imagine that is the case. I could score it right every day of the week in a blind test vs. any other well-functioning amp/receiver. It is that clear.
Nothing to spend any money on. I bought it at a flea market for around $20.
I'll give it away as a repair item. Or if I throw it at the recycling station.
For that time, 1979, ok or, mediocre performance.
Here it is by the way::)
Screenshot_2026-02-14_175920.jpgScreenshot_2026-02-14_165653.jpgScreenshot_2026-02-14_165702.jpg
Get your point. But that would pull 'everything' to a psychological level and assume that this 70s amp and a recent one have identical output overall and there would not be any differences between amps.
Not quite. There may be real differences between two pieces of equipment. Measurements will verify that they exist, and quantify them. OTOH, subjective evaluations may assert that differences exist when measurements show there are none.
In all cases, assertions based on subjective impressions are to be taken with a good degree of initial skepticism, whether they are eventually proven right or wrong.
WXA50 has loudness too, at least manual shows, that equalizer can be set to auto, where it does correction depending on volume. Other feature is bass extension. It simulate low bass with small speakers.
Damping factor is a relic from tube era. It had some meaning, when it was a single digit value.
Indeed. Once the 'Damping Factor' (which is nothing of the sort!) gets over 10, it will have a trivial effect on the loudspeaker's frequency response. Bear in mind, that 'damping factor' is not only the amplifiers output impedance, but also the 'there and back' resistance of the loudspeaker cables in series with the loudspeaker's impedance.
Except for Single Ended Triode amplifiers, especially those without feedback, I wouldn't be at all concerned about amplifier damping factor, even with tube amps.
S.
Okay.
As it was a sidestep about loudness contours, I used low volume(s). I know the basics about the Fletcher Munson curves. There are many amps with different executions following the same principle. The sansui au101 has a bit of a 'it's not a bug, it's a feature' in that it gives a slightly warm and rounder bass contour, which also does well at average listening volumes (I rarely play really "loud") . Other than how my Luxman L2 and Pioneer Sa-5300 do it. Which is way more V-shaped.
The au101 with loudness contours activated has a different bass profile compared to the au505 on initial settings. The au505 is not louder, it just seems to get to lower frequencies. That's why I doubted about still having a subwoofer, because the sansui au505 seems a keeper.
I own a small footprint B&W asw608, which goes to a reasonable 23hz and does well at the exact crossover point of around 48hz (following the loudspeaker's manual) with the Yamaha wxa50. But there seems to be more bloom below the threshold with the au505. Making it harder to find the right cross-over point, to a degree that I doubted about using the sub at all.
The au505 is not really the loudest by definition. Nothing that feels compressed or v-shaped. Bit organic, very subjective :)
View attachment 511085View attachment 511086View attachment 511087
I guess it should sound off in that case. There's always someone who likes to repair it :)
Electric damping of a speaker is regulated by total resistance of the circuit. The higher resistance, the less damping. Total resistance consist of:
- voice coil resistance, could be about 4 Ohm,
- speaker wire and connectors, could be about 0.1 Ohm,
- amplifier resistance, which is specified as "damping factor".
In a passive speaker, also the crossover.
I own the wharfedale 4.2 loudspeakers and have them placed in a well treated room.
This morning I decided to switch between my classic Sansui au505 and modern class d Yamaha wxa50 and play some jazz (Blue in Green by Miles Davis). With the Yamaha having a high damping factor and the sansui au505 a low one.
I will try to describe the "illusion" as well as possible. I will not make pro's and cons because those preferences are different from user to user.
High damping factor (modern Yamaha):
With the 3-way loudspeakers on stands, the bass seems to come right out of the woofer in front. It is tightly controlled, hefty and the idea that a subwoofer can seemlessly connect "sonically" is clear as it creates seperation in the bottom layers. I think this is probably the most accepted application as it is technical-philosophical more sound. And it adds space for selling subwoofers. Which Yamaha does as well. It also serves a modern market.
It seems to utilize more potential from the woofer of the same standmount loudspeakers. The bass blooms in bottom end territories that it seems to get take more advantage in what the loudspeakers are capable of by themselves. The bass sounds like it expands to where the stands of the 3-way system are as well. Resulting in what some might describe as more of a "holographic sound" due to more movement of the voice coil. But at the same time I would never have bought a subwoofer having an amp with a lower damping factor as it is difficult finding the extension line.
As much I get the modern technical idea behind high damping factors I think that especially for Jazz or any accoustic types of music a lower damping factor seems to be more 'sound' to the natural reproduction as there are no device-factors as with electronic bass (amps) and synthetic ones.
But getting back to lower damping factors would trouble a more modern eco system of loudspeakers and subs as well as a majority of users preferring 'tight' bass.
Any takes on this topic? :)
Using two different amplifiers add variables that may be unaccounted for. If truly just trying to see how damping factor affects the sound, use the same amplifier, add a resistor between the amplifier output and the speaker, and then level match.
This is a good video covering damping factor:
The auto equalizer on the Yamaha wxa50 and wxc50 is not its best feature. There are also no ways to reproduce it with their 3 standard EQ sliders. Sounds like a big compressed "thing". Almost for people who like their music pumped up. I usually have it on bypass. There are better executions of loudness contours.
Sansui specifies damping factor 50 at 8 Ohm, which means 0.16 Ohm.
Wxa50 is measured as 62 at 4 Ohm, which means 0.06 Ohm.
So we have total resistance for Sansui 4.26 and for wxa 4.16. The difference is about 2%. Do you really believe, that it matters?
You forgot that speaker impedance is not constant, but frequency dependent. Also you forgot about influence of low pass filter in speaker. Also both speaker filter and bass driver impedances are complex values. Thus interaction between amplifier and speaker is much more complex than can be seen from your calculations.
Hmm. I wrote about electrical damping, where resistance (not impedance) is a reason for loss of resonance energy. It was about understanding of damping factor, not about interaction between amplifier and speaker. While your comment is true, you seems to misunderstand my statement.
By the way, I did some googling and found this measurement done on TS speakers. Looks perfectly normal to me. Measured to have 86 dB sensitivity.From #273 in this thread:
You can't have a good loudness without acoustical measurements. It is properly done in AVRs. Examples are Yamaha YPAO Volume and Audyssey Dynamic EQ.
I liked Yamaha implementation and was curious, how it works in WXA50.
The issue is that your original post is not applicable to speakers that have inductors in series with the woofers, which is the vast majority of passive speakers used in home audio. If someone does not know that, and uses your advice to calculate damping factor, the results will be incorrect, sometimes far off from the actual damping factor. Garbage data in = garbage data out.
True, that I omitted crossover :)
It simply means, that you have to include resistance of series inductor, which is a next fraction of Ohm. Anyway, all this was only a simplified calculation. Feel free to do it better, becaus generic complains provide nothing.
For reference, here is the damping factor for my system, both with passive crossovers in the speaker and without passive crossovers:
With passive crossovers:
All active without passive crossovers:
With the passive crossovers in the system, the main reason for the low damping factor is the DCR of the inductors in series with the woofer. So much so that the output impedance of the amplifier and the resistance of the speaker cables are negligible. Only when the passive crossovers are removed do the amplifier output impedance and speaker cable resistance have an appreciable effect on the damping factor in my system. Note that the DCR of the inductors in my passive crossovers were rather high.
EDIT: Note, however, that the amplifier output impedance and speaker cable resistance do effect the frequency response of a passive speaker, depending on how non-linear is the speaker's impedance.
Only when the passive crossovers are removed to the amplifier output impedance and speaker cable resistance have an appreciable effect on the damping factor.
Damping factor is a property of an amplifer, just an weird presentation of amplifier output impedance. You seem to use some other definition. Unless you specify what it means to you, your graphs tell nothing.
Tbh, anything about damping factor goes out the window as soon as there's a passive crossover of any meaningful complexity in between amp and driver.
