this is just some interesting info I think fits here
Yea Mark had it nailed right on what should be defined and marketed as HDA.
He then got kicked out of his seat on the CEA/CTA board for his efforts.
He was told "off the record" that his position was " bad for commerce".![]()
I am unsatisfied with your answer. 24 bit systems don't have a volume knob? Mine does.
1. There are no stairsteps.
2. 16bit is linear (low distortion) - we stretch and compress it all the time (linearly) with the volume control.
3. The littlest bit is said to be as linear at the rest of them when we have proper dither.
So. What's the deal?
Ah, so you do have a heart after all. I'm elated. LOLThat songs all about having hart in the face of life's knocks. Ignoring the humans nonsense and raising high, back on top.
I thought it appropriate, if you listen to the words rather than just think the title is about being flippant. That's not what the song is saying... That's not what I was saying.
Yes, if you arbitrarily assign a value of 6dB per bit.
Do we really do that in practice?
Don't we have a volume knob which we rotate to assign however many (even fractional) dB of in-room SPL to the so-called 96dB for the 16 bits on the disc?
If I turn the knob a little more to the right, for peaks of 116 dB in room, playing redbook, do I not get 7.25dB per bit from a 16bit source? (16 x 7.25 = 116)
If I play a 24 bit source at that same 116db peak in room, did I not select 4.83 dB per bit?
24 bit = 144dB at 6dB per bit, 16 bit = 144dB at 9dB per bit.
Straighten me out.
I drove from Charlotte to Carrboro today for the inspection of my new place there; 2.5 hours. I have iTunes automatically compress files to 256kbps when transferring to my iPhone. Being the old dog I am, there were a lot of 60s/early 70s recordings on there. They sounded fine. Then on came Edith and the Kingpin from Herbie Hancock's River: The Joni Letters. This is an amazing DDD recording. And even at 256kbps, even through my bog-standard Ford audio system, it was still amazing. Really stood out from those older recordings. It's about the recording, gentlemen. Always has been.
Tim
Amen to that.What really takes me by surprise is my impressions of other threads in the web sphere I have surveyed, as reactions to the Reiss paper have exploded. I have very distinct objectivist leanings, one reason for being active in this forum. But, it is becoming quite clear that the ostensibly "objectivist" forums are so loaded with their own cynical, contrarian biases that they cannot even read or interpret a very well done scientific paper, like Reiss', with any degree of objectivity. I have no love for total subjectivists, but extreme "objectivists" are not necessarily any better, in my view.
Well, we've known for awhile, at least where Amir is posting, that well-trained listeners can consistently differentiate hi rez from CD.
Now we have a study confirming it statistically, and even a theory of what these well-trained listeners might be hearing: Filtering artifacts. Pre-ring.
You will get nowhere with a PS3 rip of an SACD because you still have the PCM vs. DSD issue.
And, as the opening post of this thread describes, we do not "know" anything for sure. It is perceptual. We know how RBCD and hi rez measure, but there are still many open questions as to audibility. Given the uncertainty of all that, you just have to reach your own conclusions based on listening, unless you want to conduct your own comprehensive double blind tests with a large number of subjects and samples. I do not need to do that. I have reached my own conclusions which are good enough for me, if no one else.
Ah, have we proved that THAT is audible now, too?
Officially or not?
And what conclusion do you think is defensible, from a sighted A/B? How many caveats would you attach?
I feel your pain about not being able to hear the difference between hi rez and CD, which have differences measurable by traditional audio measurements.
But, apparently, per a different thread, you can hear the difference between WAV and FLAC versions of the same music file, which have no scientifically provable differences in their audio measurements. More power to you and enjoy!
Oh sure you can tell if they're from the same master. Why wouldn't you be able to? But that's not the point; comparing SACD layers is invalid … way too many possible variables. As we covered previously.1. Not surprisingly, you missed the point once again. ceedee was suggesting that if he had a rip of an SACD done on a PS3, he would be able to tell if the hi rez stereo program, which is in DSD, had used the same master as the CD layer, which is in PCM. My point was that was not possible, DSD vs. PCM being one of the issues. I said nothing in that post about audibility or in praise of DSD. Got it?
Waldrep makes some really excellent points. And, he might help to clear up much confusion on the subject. The key cautionary notes for listening comparisons between hi rez and RBCD relate to the provenance of the recording listened to. To really hear the difference, it must be hi rez throughout the chain, starting with the recording. Even hi rez remasters from analog will not do. (That was one flaw in Meyer-Moran.).
And, as Mark points out, that is often tough to do, especially with pop recordings. So, many user listening anecdotes about not hearing a difference with hi rez may be flawed by this.
BIS appears to offer the largest catalog of hi rez on SACD, and I enjoy their releases a lot. But, they switched format/resolution a few times. Their initial hi rez releases were done in DSD. Then, they switched to 44k/24 for a long period. And, for the last few years, they have used 96k/24 exclusively. But, even the 44k/24 releases sound generally quite good to me in Mch. I am also generally happy with Mch BD sound at 48k/24. I have also listened to some DSD256 and some DXD, with the rapidly dimishing sonic returns you might expect vs. more main stream hi rez at lower sampling rates.
Although, easily the best recording I have heard to date was done at DSD256. However, its excellence might be due more to special care in miking and engineering rather than ultra resolution.
So, the hi rez shell games Mark alluded to are a rarity in classical music, except for the remasters from analog.
