Grooved
- Joined
- Feb 26, 2021
- Messages
- 679
- Likes
- 441
Right, same thing with Roon, I use both apps and both are limited to Tidal and Qobuz. Maybe the problem is that Tidal and Qobuz are the only app that provides a true exclusive mode and make the DAC switching its sample rate to match the one of the each file.I tested Amazon Music HD and you can get bitperfectby matching manually the SR on the DAC with the one of the file, but it doesn't change automatically. It still use the OS audio setting for your DAC, even if you select "exclusive mode", and Deezer and Spotify don't offer exclusive mode at all.A world where you could put Spotify, amazon music etc etc into UAPP would be ideal. But I appreciate its not within the developers gift to make it work.
I bet that if they all provide an real exclusive mode, Roon and UAPP wouldbe able to add these services
