You could use the affordable ADC from MiniDSP and combine it with the
Audiophonics input module (supporting SPDIF RS422 to AES/EBU, SPDIF, SPDIF TTL, and Toslink). This board utilizes the same processes and components found in high-end equipment; you would just need to source the appropriate connectors.
There is also an option to retrofit the E1DA Cosmos ADC with an SPDIF output; the manufacturer even provides custom firmware for this purpose. You could pair this with the same board mentioned earlier—it would be hard to achieve higher quality than that.
Additionally, you could use an AK4118 or AK4137/AK4118 board—featuring a high-quality sample rate converter—to handle the conversion from SPDIF to AES/SPDIF/Toslink. This costs approximately €70–120, depending on the specific version, plus the cost of the ADC.
