I will stick with easy and passive as you reuested.
The $300 a PAIR, HIVI kit is complete and did Extremely well here with a slightly modified crossover that is well documented. This has been a fan favorite for a long time in the DIY forums.
With the squared edges it will be easy to veneer for a novice. EASY to build
https://www.amazon.com/HiVi-Bookshelf-Speakers-Near-Field-Speaker/dp/B0721ZQXDG
(5 left in stock now but it seems to go in and out of stock every couple weeks, so I bet more are coming)
A potential high end design done by SB Acoustics themselves using their Satori Drivers can not be ignored.
Includes finished cabinets, you assemble. EASY.
Satori Ara $1395 a PAIR with the dimple soft dome, (add the beryllium tweeter for $500 but why?)
https://www.madisoundspeakerstore.c...ra-2-way-speaker-kit-pair-with-cabinets-2694/
The PE Samba kit has a flat pack, you just need to buy a few extra things (like binding posts)
Dayton RS drivers are excellent, excellent drivers comparing well to much more expensive gear. I have never seen this unit measured however.
$164 each ($328 a PAIR)
https://www.parts-express.com/Samba-MT-Bookshelf-Speaker-Kit-with-Knock-Down-Cabinet-300-7121
I have similar Dayton RS drivers in one of my DIY actives and in my case they are excellent.
CSS is all over you tube now with two of the bigger audio bloggers promoting it.
The GR research Kit is back again on the Youtube circuit again.
I see no reason not to try these kits.
The CSS kit is using a very solid/famous rebranded Wavecore woofer. The main thing about that woofer as I understand it, is it models well down into the low 30hz's. You are paying for that so little benefit if using a sub/subs. Keep in mind it is a 6-7" driver and is not a replacement for a subwoofer - so at high volumes that woofer will be working very hard on low bass and reaching high excursion levels(potential for HD and IMD distortions).
Based on the testing I have seen over at voice coil I think that that tweeter is over priced and nothing I would buy on it own, however the CSS designers have likely worked into the speaker very well. You are paying for that however.
GR Research makes a totally decent kit. No doubt about it. He also sells tube connectors and is often in arguments in the comments section on various forums that paint him as arrogant and childish when challenged. Not totally my cup of tea. He makes his money the old fashioned way and I understand that means he sticks to his guns when his cash flow is involved. That may not bother you. I don't trust him, though at least he puts him self out there on front line. I bet any number of other folks in the business are not completely trustworthy either but they hide away. In any case this to explain why some while shy you from his wares.
The kit has a budget tweeter and a seemingly decent woofer pair with a fair crossover and the results measured fairly well here.
I've never heard the GR-kit nor have I heard the Parts Express Samba kit, however the PE kit has a flat pack, likely better drivers and a as of yet un tested crossover.
I'd personally buy the PE kit over the GR kit. Then I'd buy the HIVI 3.1a over the PE kit. The CSS kit seems pricey with the flat pack and knowing a big chunk of the value is in the bass reach. (I use subs for bass), so maybe I would just jump into the Satori Ara and skip the CSS. I'd be very curious what the CSS offers over the HIVI kit, I am betting not much.
Someone already mentioned the BMR kit but that one is affordable finished, you save very little buying flat packs and the kit (you would have fun I'd think). It is extremely well regarded.
Also you could contact Bamberg Audio, maker of higher end speakers. He has un advertised DIY kits, including some 2-ways.
http://www.bambergaudio.com/
Not sure how much you have explored DIY and these links are more for fun (not to add confusion) as the kits do not include flat packs and some are very complex. As you likely know already some kits can be made in a weekend and some will takes weeks or longer.
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
https://meniscusaudio.com/product-category/speaker-kits/
https://meniscusaudio.com/product/the-helios-loudspeaker-kit/
this is a big 2-way with PR using very nice drivers $1800 pair without cabinets. You could source some.
In any case most DIY kits in the 1k-1.5k budget class do not have flat packs as it is "assumed" that more seasoned builders are attracted to these and have tools/skills.
Really without building you own boxes there are much more limited options. That doesn't mean you would not get a sweet kit with a flatpack. Just less options.
