Hi,
I am a beginner with REW and I am sorry if this question sounds stupid
I recently started with speaker measurements in order to use Audyssey One scripts, and I noticed that one of my Atmos speakers shows unusual distortion between 1kHz and 8kHz (I get the same curve on every measurement so it's not related to temporarily room noise or such external factor). I have 4 similar ELAC IC-DT61-W in-ceiling top speakers and only that one has this distortion curve, all others have normal curves (all measurement taken in the same conditions). These measurements were made with an umik-1 with calibration file, atmos sweeps with time reference, on a Denon x3800h with normal speaker outputs for 2 speakers, and pre-amp with Fosi Audio TDA7498E for the 2 others including the speaker with the distortion problem.
I was wondering what can cause this ? Can it be a defective speaker ? Wiring ? External Amp problem ? Speaker improperly attached into the recessed ceiling, like vibration ? External factor in the room ? I am also wondering what are the consequences of this higher distortion for the calibration and/or the listening experience ?
First image with 3 measurements of that 'problematic' speaker distortion :
The other atmos speakers with normal curves (3 measurements per speaker), note that the one with higher distortion bellow 200hz is the other speaker on the pre-out.
The SPL curve for the 'problematic' speaker (one of the measurements) :
Any clue would be much appreciated. Thank you very much !
