HIFIMAN Susvara Headphone Review
Rate this headphone:
    Votes: 233 57.4%
    Votes: 75 18.5%
    Votes: 33 8.1%
    Votes: 65 16.0%
Hi everyone,
right now we run the Arya Unveiled on a Fiio Retro Nano. 35/60 is my personal max volume with this combination, my wife wont go any higher than 30. I will try that mentioned album later thats supposed to be quiet.
We also tried the Susvara with the Retro Nano quick and for my wife thats actually loud enough, i personally miss a couple of db, before it gets too loud for me on that Nano as well.
I guess the 5K may not be enough at the end, but there seems to be nothing better on the market with more power (with battery only) and real systemwide PEQ and being compatible with the PS5.
Strange. I have no trouble at all driving the HE400se, Edition XS, or Deva Pro with my Qudelix 5k at 1 volt in unbalanced mode to very loud levels when required, let alone 2 volts (or 4 volts in balanced mode)!
Listening to the Secrets album by Allan Holdsworth (FLAC) with my Deva Pro from a Motorola Edge 60 Pro (using either MediaMonkey Pro or foobar2000) I get the following volume settings at the maximum sustained volume level I would want to use. The second image is when the voltage is set to 2 with +6dB on tap.
What you’re saying isn’t strange at all.
To try something else, I connected the HE400se to my smartphone using a FiiO KA11 with no EQ applied and with the album you mentioned I only need around 55% software volume for a very good listening level. Then I switched to Julia Bullock’s "Walking in the Dark" (and it’s not even one of the most demanding albums, quite the opposite...) and I found myself using 100% volume just for a moderate listening level. If I were to apply EQ, it wouldn’t be enough.
As I said, it depends a lot on the music you listen to and how it was recorded/mastered.
Some time ago, when I got together with a few other people to do some comparisons, I ended up with the Susvara in my hands. I kept repeating that I couldn’t hear any difference in sound quality between one amplifier and another, as I expected, but I still realized that they need a lot of power, especially if you want to have some headroom for very quiet or highly dynamic tracks, even more so if you plan to use EQ. In my opinion, the Susvara really needs an amplifier capable of delivering at least 1.5/2 W.
Technically, nobody needs 200 hp on public roads, until you find yourself on a mountain road with five passengers and a full trunk.
@Sebby
could you please send me a link to the holts the planet album on apple music, if available? Its a lot of the same, not sure which album and maybe specific song you mean that is too quiet?
I have listend to 13 different versions of said album and the song "Mars the bringer of war" and instead of using as max 35/60 volume steps i could go up to 40/60 steps before my ears starts to really hurt.
@Sebby
That album has many tracks that start at a very low volume, and there are some parts in the middle where they suddenly “explode”, before going back to quieter levels. Maybe you don’t like very dynamic tracks when the volume gets really loud, but if you set the volume to a comfortable level for the explosive part, you end up missing a lot of detail in the quieter sections.
Anyway, I don’t have Apple Music, but on Tidal the album is like this. Have you checked whether you have volume normalization enabled?
Also, the other album I posted in the screenshots has the same characteristic. The first track in particular starts very quietly and then suddenly explodes when the vocals come in at a certain point.
@Sebby
Actually, I really enjoy music with a lot of dynamics. It’s a bit like HDR, the idea isn’t to constantly adjust the volume between quiet and loud parts, but to listen at a steady level so you can hear the music as it was intended. That usually means setting your max volume based on the loudest passages.
I don’t use normalization or anything like that, so I do end up adjusting between albums. But I totally get that some people prefer to tweak the volume to their own taste.
Thanks for the pictures, I’ll give it a try tomorrow! By the way, Apple Music actually has a feature to import playlists from other streaming services. You just need accounts on both platforms.
