- Joined
- Jul 9, 2020
- Messages
- 516
- Likes
- 1,401
This looks like an additive PEQ
How much headroom do you use in Roon?
Well, the highest peak is around 6dB. So 6dB or less if he uses volume normalization in roon.
and boring sound - your exciting sound vs our boring sound will sound the same when you close your eyes, and level match
I then put back on my trusty HD600 one day and couldn’t believe what I heard. I started doing some quick a/b listening between the two and quickly realised that I had upgraded the bass and subbass qualities of the 600 via the Susvara..but at the expense of the mids and treble. This felt so counter intuitive that I started questioning my senses. Slept on it, did the same experiment the day after and ended up with an even greater appreciation of the 600…and genuinely disappointed with the Hifiman.
This lead me to a/b the Sus with my Sundara and HE500 and curiously enough I ended up prefering both.
Saying you can't recommend the Susvara, not linked to real world.Seeing how crazy wrong it is to say another audiophile doesn't listen to music, we know how much you value reality.
Somehow you think performing a measurement precludes us from listening to music. I can assure you that we listen to quite a lot of music here.Saying you can't recommend the Susvara, not linked to real world.
Unplug your machines and listen music.
In one of the Harman papers it say something like the effect of the excess phase of the headphone response is small. When they say that, they surely mean on spectral balance correct?The system's excess phase is close to 0 per frequency. You can find excess phase measurements of few headphones, it's usually flat or close to flat. (Oratory have some) The headphones as an isolated system is linear. As long as both headphones have the same leakage tolerance, if you EQ them to the same target next to the eardrum of one individual, they'll sound same.(ignoring distortion here).
leakage tolerance is how FR of headphones change when their air seal is broken. In this case EQ setup I described above, only leakage tolerance between headphones can make a difference.
Agreed! I myself and most people would fail ABX my 5% THD SET amp to my Schiit Midgard (118 dB THD+N) on a DBT level match to 0.01dB test when it comes to A/Bing a linear impedance headphone such as the Susvara since the FR is exactly the same (damping factor is more than 10:1 on both amps). 5% THD may sound like Huuuuge distortion on paper but it’s incredibly nuanced in reality. I’d say with linear impedance headphone, it’s the visual perception of glowing tubes that contributes to the experience rather than its distortion sound effect box. But if I use something like Focal Utopia, it’s going to sound different with a SET amp against a SOTA amp due to non linear impedance/frequency curve where damping factor changes drastically when plotted against the frequency and therefore I’ll likely to pass the DBT ABX level matched test.
I think amirm and many others are way too fixated on measurements. Measurements horrible? Then of course he will subconsciously enjoy it less.Somehow you think performing a measurement precludes us from listening to music. I can assure you that we listen to quite a lot of music here.
If you are just going to sling insults because of a negative review, why don’t you go read the 50% of the audio press who never give negative reviews at all (but I personally don’t get much value from that).
I don't need measurements to tell me that, for instance, Grado headphones sound like crap.
No I haven’t tried it yet. I haven’t come across any credible frequency response of it and my rule is: no frequency response no new headphone.Have you tried the JAR600? It fixes the shortcomings of HD600 but without altering its midrange tonality as much
Music? What is this music you speak of?you must be kidding...
this forum must be something like the Truman Show, you really can't be people listening to music
Is there any other headphone to be reviewed that would generate as much controversy as this?
After owning a half dozen pairs of speakers, a dozen headphones and using a measurement mic and room EQ, I have learned that frequency response correlates massively with what I hear.I think amirm and many others are way too fixated on measurements. Measurements horrible? Then of course he will subconsciously enjoy it less.
High price + HEA press/reviewers unabashed praise = screaming for anything but equally high praise.Is there any other headphone to be reviewed that would generate as much controversy as this?
I’m not sure whether or not ASR can generate as much controversy with other future reviews, but there are plenty of bad flagships out there.Is there any other headphone to be reviewed that would generate as much controversy as this?
Maybe the ZMF Caldera review? It even pulled Zach into discussions. I guess Hifiman is too big so Fang Bian won't come over here.Is there any other headphone to be reviewed that would generate as much controversy as this?
ZMF Atrium (HD650 with a piercing treble peak anyone?)
I have seen that thread. I was curious how the Caldera would measure like over a proper rig as many frequency responses I have seen over the net almost portrays it as having near-mint eargain, which totally went against what I heard when demoing it. To me it sounded like a more polite Edition XS.I'll measure well past 100 Hz except for bass given that it's dynamic driver. Zach probably won't sent any headphones to him since I think he believes that the panther scoring on his headphones is determined by the headphone pads that his headphones are currently equipped. Caldera pads would probably score higher than stock pads on the panther scale from how I perceived it as closer to HD600 than HD650 (more linear than V-shape). Unless somebody sends an Atrium with stock pads to Amir, you won't see it being measured here
