Hifiman Sundara Review (headphone)
SlowCar
Will Lg phone with good audio (G8x, G7) have enough power to listen sundara?
solderdude
The Neitherlands
Only when you are not going to play loud. Will be fine at comfortable listening levels.
jawbfl
Morocco
To import this PEQ profile into 'Equalizer APO', use:
Otherwise, see my PEQ guide.
For those who don't have PEQ-capable app, and want to use GEQs instead.
Preamp: -7.7db
32 7.2
64 1.0
125 -0.4
250 -0.2
500 -0.1
1000 -0.4
2000 2.5
4000 -0.5
8000 -2.0
16000 -0.1
Preamp: -7.0db
20 4.7
25 5.1
32 4.7
40 3.9
50 2.7
63 1.6
80 0.6
100 0.2
125 -0.0
160 -0.1
200 -0.1
250 -0.1
315 -0.1
400 -0.2
500 -0.1
630 -0.1
800 -0.1
1000 0.0
1250 0.2
1600 0.8
2000 2.0
2500 1.5
3150 0.4
4000 0.1
5000 -0.3
6300 -4.3
8000 -0.5
10000 -0.3
12500 -0.3
16000 -0.4
20000 -0.2
If you want to import into "Wavelet" (Android App):
GraphicEQ: 20 -0.2; 21 -0.2; 22 -0.2; 23 -0.2; 24 -0.2; 26 -0.2; 27 -0.2; 29 -0.2; 30 -0.2; 32 -0.2; 34 -0.2; 36 -0.4; 38 -0.7; 40 -1.0; 43 -1.4; 45 -1.7; 48 -2.1; 50 -2.4; 53 -2.8; 56 -3.2; 59 -3.5; 63 -3.9; 66 -4.2; 70 -4.5; 74 -4.7; 78 -5.0; 83 -5.2; 87 -5.3; 92 -5.5; 97 -5.6; 103 -5.8; 109 -5.9; 115 -6.0; 121 -6.0; 128 -6.1; 136 -6.1; 143 -6.2; 151 -6.2; 160 -6.2; 169 -6.3; 178 -6.3; 188 -6.3; 199 -6.3; 210 -6.3; 222 -6.3; 235 -6.4; 248 -6.4; 262 -6.4; 277 -6.4; 292 -6.4; 309 -6.4; 326 -6.4; 345 -6.4; 364 -6.4; 385 -6.4; 406 -6.4; 429 -6.4; 453 -6.4; 479 -6.4; 506 -6.4; 534 -6.3; 565 -6.3; 596 -6.3; 630 -6.3; 665 -6.3; 703 -6.3; 743 -6.3; 784 -6.2; 829 -6.2; 875 -6.2; 924 -6.1; 977 -6.1; 1032 -6.0; 1090 -6.0; 1151 -5.9; 1216 -5.8; 1284 -5.7; 1357 -5.6; 1433 -5.4; 1514 -5.2; 1599 -5.0; 1689 -4.7; 1784 -4.5; 1885 -4.2; 1991 -4.0; 2103 -4.0; 2221 -4.0; 2347 -4.2; 2479 -4.5; 2618 -4.7; 2766 -5.0; 2921 -5.3; 3086 -5.5; 3260 -5.7; 3443 -5.8; 3637 -6.0; 3842 -6.1; 4058 -6.2; 4287 -6.4; 4528 -6.6; 4783 -6.8; 5052 -7.1; 5337 -7.6; 5637 -8.4; 5955 -9.5; 6290 -10.2; 6644 -9.7; 7018 -8.6; 7414 -7.8; 7831 -7.3; 8272 -7.0; 8738 -6.8; 9230 -6.7; 9749 -6.6; 10298 -6.6; 10878 -6.6; 11490 -6.5; 12137 -6.5; 12821 -6.5; 13543 -6.5; 14305 -6.5; 15110 -6.4; 15961 -6.4; 16860 -6.4; 17809 -6.4; 18812 -6.4; 19871 -6.3
Otherwise, see my GEQ guide.
Thanks, I tried this 31 EQ with my Sundara and it sounds great, bass was really lacking, also the fixes to the highs seems to open perceived soundstage a bit but increased sibilance on some songs as a side effect.
Jman841
Amir vs Oratory1990:
Amir vs Jaakkopasanen (measured by Oratory1990):
Oratory1990 vs Jaakkopasanen (measured by Oratory1990):
PEQ profile by Amir (from my post #2 above):
Preamp: -8.6 dB
Filter 1: ON LS Fc 50 Hz Gain 8.0 dB Q 1.0
Filter 2: ON PK Fc 2112 Hz Gain 2.5 dB Q 1.5
Filter 3: ON PK Fc 6300 Hz Gain -4.0 dB Q 4.0
PEQ profile by Oratory1990:
Preamp: -5.5 dB
Filter 1: ON LS Fc 105 Hz Gain 5.5 dB Q 0.71
Filter 2: ON PK Fc 460 Hz Gain 1.3 dB Q 2.3
Filter 3: ON PK Fc 900 Hz Gain -1.7 dB Q 1.2
Filter 4: ON PK Fc 2000 Hz Gain 6.0 dB Q 1.0
Filter 5: ON PK Fc 3000 Hz Gain -4.4 dB Q 2.5
Filter 6: ON PK Fc 4600 Hz Gain -4.5 dB Q 3.5
Filter 7: ON PK Fc 6000 Hz Gain 3.0 dB Q 2.0
Filter 8: ON PK Fc 7500 Hz Gain -1.0 dB Q 3.0
PEQ profile by Jaakkopasanen (measured by Oratory1990):
Preamp: -5.1 dB
Filter 1: ON PK Fc 17 Hz Gain 4.1 dB Q 0.42
Filter 2: ON PK Fc 1983 Hz Gain 14.2 dB Q 1.00
Filter 3: ON PK Fc 3197 Hz Gain -13.4 dB Q 0.39
Filter 4: ON PK Fc 6825 Hz Gain 9.5 dB Q 0.66
Filter 5: ON PK Fc 19549 Hz Gain -8.7 dB Q 0.46
Filter 6: ON PK Fc 218 Hz Gain -1.3 dB Q 2.11
Filter 7: ON PK Fc 1403 Hz Gain 0.9 dB Q 6.88
Filter 8: ON PK Fc 4830 Hz Gain -3.0 dB Q 6.22
Filter 9: ON PK Fc 6042 Hz Gain 3.5 dB Q 3.15
Filter 10: ON PK Fc 6913 Hz Gain -2.9 dB Q 3.73
It looks like you're using Oratory's EQ for the old version of the Sundara, He has an updated version of the 2020 version which is what I am assuming Amir measured (Updated pads).
Jman841
I made my own EQ which is a mix of Oratory and Amir's, Amir's in the upper mids and treble, Oratory in the lower mids and bass. I found Oratory's has too much energy in the treble and makes them sound harsh. It's very apparent in metal music with a lot of symbol and snare hits.
AdamG
Proving your point makes it “Science”.
Moderator
Reality
Welcome Aboard @Jman841.
ReaderZ
This is the first review here that measured FR fit my impression of the headphones perfectly.
Tarkus1984
Mexico
Hey everyone, new member here. I just started to get into headphones and I used the updated EQ from Oratory and I simply love the sound coming out of my Sundaras now!
What would be your recommendations to transfer these type of 13 band digital EQ settings into a 4 band physical one? I have a Schiit Loki+ coming hopefully soon that I plan to use with my turntable setup and would like to know where to begin so I tweak it to something similar.
Your tips and tricks will be greatly appreciated!
solderdude
The Neitherlands
Schiit Loki+ is a tone control. Use it as such. It cannot replace EQ because the bands are too wide.
frix
So I have an EQed HD800. Does an EQed Sundara have a different quality to it which would be worthwhile to own besides my HD800?
Cahudson42
It's often suggested that you have an example of a Dynamic (speaker technology like) HP like your HD800 and a Planar (membrane type) like the Sundara, as they can 'give different presentations'..
But you won't know until you try both..:)
Astroboydivx
I'm thinking of buying the Sundara. Given I have an iPhone/iPad, would it pair well with Hidizs S9, or is there another portable amp I should consider?
Thanks!
0RF30
Thanks!
Also think about E1DA 9038 D or Luxury&Precision W1/W2.
Best results with Sundara on my side were with Hidizs S9 and Luxury&Precision W2. With E1DA 9038S/D it was too "holographic", imaging/soundstage was weird and bass texture was lacking, insane details with this pairing though.
Oh, careful, it's seems to be a usb current limitation with iPhones which seems to be problematic with W2 (not with W1 if I remember correctly).
@amirm can you make a post on how do you create EQ for any headphone? I understand the end results are largely personal taste, but it would be very valuable to know how do you make those choices. Do you adjust EQ based on the FR curve? Many thanks!
I have had a lot of requests for this so let me do a video on it.
Inazzab
oratory1990's measurement looks generally similar, at a 'high level' view
Those are measurements of the pre-2020 revision of the Sundara. Here are the measurements of the latest revision, which look even more similar to Amir's review
