solderdude
RHO (and me) are telling you that the (substantial) dip at 10kHz, caused by pinna+ear canal simulation are always at the same frequency in a HATS.
The concha and earcanal in the HATS are chosen to be somewhat close to reality. Not as close as the BK5128 but reasonable average.
Look at measurements made by Tyll... they ALL have a peak at 10kHz (which also is due to the concha simulator) which also is not correct.
The reality (my ears and those of others) due to all pinna being different (as different as fingerprints I am told) and not having the same dimensions (pinna keeps growing all your life) the dip in someone else's ears may be higher or lower than that of the HATS.
Also your brain is used to the dip you have near that frequency as well.
It is not included in the Harman target. I have never gotten a clear answer why not other than the curve is averaged (very, very heavily smoothed)
Do yourself a favor and ignore everything above 8kHz in Amir's and Ora's measurements and consider that above 6kHz accuracy is already out the door. You should not EQ this either (which Amir repeatedly remarks in his reviews.
measurement 'error' or rather 'artefact' or 'inaccuracy' and downside when using a HATS for headphone measurements.
For Sundara... it does have a peak but in a spot where the HATS has a dip so you can't see it in the plots.
Depending on how different your ear is from the fake concha and ear canal from the HATS you may hear the peak or not.
Your ear seems to be pretty close to that from the HATS so you don't hear it as it cancels out.
