What an attitude?It turns out, it is your lucky day today! I was starting to lose hope after your 59th message on the same topic but hey, when there is a will, there is a way.
I happen to be listening to music with Sundara, and 5K is not too far away so I will test them for you. Yes, Sundara sounds as lovely as ever with 5K, and with EQ enabled, it gets as loud enough to cause pain with 12db more to spare.
Hi,Q5K work fine with my HE-4XX (and HD 660S), i'm using an OKSC balanced 2.5mm cable (for both)... https://www.amazon.co.uk/gp/product/B0B58ZMMFW
You are most welcome.What an attitude?
I have not asked to you read all these messages? Agree?
But thanks anyway.
Hi,
Thank you.
I will take a look at the cable .
Sounds great.It's a nice cable. Its fabric covered, quite flexible and feels 'premium' (despite its relatively low price) - I like the right angled plug as the cable hangs down when I clip the Q5K horizontally to a shirt or open hoody.
Sounds great.
3.5 - 2.5 mm
or
3.5 - 3.5 mm
It may be 3.5mm-2.5mm.
Maybe the same cable can be bought inside Europa.
I prefer not paying the Taxed ;-)
Do you agree with IAtaman?I have the 2.5mm balance to 2x 3.5mm cable for my HE-4XX. You should check the plugs that go into your Sundaras
Regarding Europa, just change the '.co.uk' to the European equivalent, e.g. for Spain...
One person wrote this message:
Qudelix 5K only = 129 € for the total setup is what StaticV3 is trying to tell you.
It will also give you EQ possibities, have enough power and can be used as desktop as well (via USB) and can be used portable.
You will be lacking 2 separate boxes, display, power supplies. Your wallet will thank you.
You may want to buy a balanced cable for the Sundara (Pentaconn2.5mm TRRS).
The Qudelix will be enough unless you want to remove the fillings from your teeth.
I guess for 15€ the money er well spend.
To the give the Qudelix K5 some xtra juice.
Do I not need a balanced cable between Sundara Qudelix 5K?
Some people say yes. Some people say no. :-S
Okay.I was not a fan of the cable that came with the HE-4XX, but it worked fine. I also apply quite a lot of EQ to the HE-4XX (with negative pre-amp), so the extra power from the balanced connection was welcome. So, you don't *need* to buy another cable, but if you want try one, the one I linked to is a good one.
Okay.
My Output level for my Sundara (EQ) is -7.5.
Therefore, it might be a good idea buying a balanced cable?
Thank you for testing it.
When I said I will test it, I was not bullshitting - I have genuinely tested Sundara with Q5K using 3.5mm SE cable. It gets very loud even with EQ applied with phone at max and Q5K volume control with 12db more to go.
