FurstMan
- Joined
- Feb 21, 2023
- Messages
- 13
- Likes
- 9
Hi,
I currently own a Beyer' DT-770 Pro 80ohm which I use on a Cambridge CX A60 connected to my PC via a USB/SPDIF PHIREE U2S interface. This headset was chosen after reading various tests, to replace a faulty AKG K550.
The construction of the DT-770 is clearly superior to the K550 (the materials seem robust and the spare parts are reassuring), the bass is also deeper than on the K550 which sometimes seemed too quiet on certain music.
However, I remain unsatisfied: the K550 had an incredible soundstage, full of detail and great precision. Enough to listen to hours of music with great moments of thrill. What I do not find with the DT-770 which gives me the impression of being often cramped and unclear.
So I plan to buy a second headset (the DT-770 will be used during gaming/discord sessions or when my girlfriend works next to me).
I initially leaned on a DT-990 250 ohm in order to find the sensations of open headphones (precision, spatialization and increased soundstage) but the very divergent opinions brought me to the HiFiMan Sundara which is equipped with planar transducers magnetic.
Do you think this one will allow me to find a wide and precise soundstage, as I could have with a K550, or even better?
Will my Cambridge CXA60 be able to power it properly? I don't even know if it's a good amp for my DT-770. (spec headphone outpout here : https://techsupport.cambridgeaudio..../202201712/CXA60_Technical_Specifications.pdf)
Do headphones with planar magnetic transducers make a real difference?
Thank you in advance for your answers, I hope I haven't forgotten anything.
Good day to you !
Good day to you !
