thecoolerplayer
- Joined
- Aug 25, 2025
- Messages
- 7
- Likes
- 5
Thank you for your reply. However, the sensitivity is 83.5dB at 50Ohm, although the ASR review measured it at 64Ohm. So assuming the worst case of sensitivity being 83.5dB at 64Ohm, and say I want to listen at around 105dB instead of 95dB - how does that change things?Topping G5 can output at least 5-6V without clipping to 50Ohm according to ASR review. (according to L7Audio it's beyond 6V).
HE6SE V2's sensitivity is 91dB/V. So even 4V output can give you 91 + 2 * 6 = 103dB.
Also, apologies for this question but could you tell me or point to a source which can teach me how I can calculate these figures myself? This is incredibly helpful and exactly what I was looking for! For example, where in the ASR review does it say that the G5 can output 5-6V? I only saw a mention of 2.1V output. So, is there a formula to calculate the max voltage that can be delivered based on other numbers?
I figured as much! However, I do see many, many people talking about how harder to drive headphones, including the HE6SE, benefit from having a more powerful amp and how it purportedly "opens them up" and "increases bass dynamics" and other such phrases. Is it really all more or less placebo? Or in my case, will the headphones sound the same whether it's being powered by just the G5 or the THX 789 with the G5 acting as just an amp (assuming both cases are volume matched ofc)?When audiophiles are talking about things are "hard to drive", they want to drive it to 120dB+ with headrooms left...
most people actually don't need that.
I am a happy man then! As a recently graduated student, it is a bit tough trying to get my next upgrade while also keeping the budget in check. I was initially going to get an Arya Stealth, but the lower price + the A/B test from this YouTube video convinced me to go for the HE6SE insteadConclusion: just use G5. no need for anything else.
