- Joined
- Dec 9, 2020
- Messages
- 369
- Likes
- 734
Indeed changes aren't so big, but still noticeable when you spent months with the other EQ. Have you, buy any chance, downloaded the previous version pdf ? I usually keep all versions pdf of his EQ related the HP I own, but I unfortunately forgot to download the previous HE400i version. I still have my EQs for the previous, but I'd like to compare measurements. Sometimes he updates EQ due to new measurements, sometimes he updates the EQ for better user customization.
Sundaras pads are softer, and highs resolution is next level
I did, yes. Measurements are slightly different and EQ is a bit more precise.
Did you try the Sundaras? I'm a bit put off by the bass distortion, as I'm a bass-tard and add a +10db low shelf on top of the harman curve (but that's because I typically don't listen very loud and bass-perception is poor at low volumes due to how our ear/brain works; but that kinda renders my point moot since distortion will be low at low volumes anyways..).
Not sure what to do. Hows the headband on the Sundaras? I typically prefer foam/leather pads over strips.
FYI, my low-shelf is 70Hz +10db Q0,8.
I attached both PDFs to this message for everyone.
