I personally have a trained neck so I am fine for using he500 for extended sessions by day for my wife she can’t stand it for any period of time. Sometimes the weight will just took all the attention and the joy of musicLots of people talking about comfort. More specifically about the weight of these headphones with respect to neck issues.
I never have an issue with headphone weight in terms of neck pain (I can go 6+ hours no problem). An issue I have with Audeze LCD's for example which are also heavy, is they're simply unstable. You can't do large swinging or fast moving head movements. Also forget about tilting your head or any of that, it just moves the damn thing.
When I went back to light stuff like HD600's. I couldn't believe it. I honestly don't think I can ever wear a planar again for anything aside from leaned back listening for a few minutes. I get they can make the clamp force greater but then you have a vicegrip on your head. You can imagine that being worse for people with neck issues. They would then have the neck pain from weight as usual, and also a horizontal gripping force, making the damn headphone a torture device.
They are the stock HiFiMAN Velour pads:Are those Beyerdynamic pads on there?
Anyway, pretty good performance, unfortunately many are riced out.
That's relevant .A word regarding EQ and power:
If any device is EQ'd by 3 dB, the Amp's dynamic range decrease by 3 dB (Half). So, if you had a 50W Amp's you remain with only 25W available.
If the same is EQ'd by 10 dB, the Amp's dynamic range decrease by 10 dB (1/10). So, if you had a 50W Amp's you remain with only 5W!
That's bad.
Now most EQ'd devices on this site are speakers and headphones.
The audio output of such device (speaker) is given by the sensitivity (SPL/m/w). In other words, how loud it sounds when checked on axis, at a 1m distance, when driven by 1W rms (2.83V@8ohms) in dB. So if you have a low sensitivity speaker (or HP), let's pick a Magnepan 1.6 with 86dB/w/m SPL, vs a Klipsch Forte-II with 99dB/w/m SPL, the 13dB difference is translated to x20 more power for the Magnepan 1.6.
If you would like to play the Magnepan 1.6 as loud as a Klipsch Forte-II at 5W you need a 200W power Amp playing at full trust.
If that would be EQ'd by 10dB, it would really crippled the Magnepan 1.6 to be driven by 20W only.
The very same is with the rested HP. It's sensitivity is the lowest, by far, among other HP in the market.
EQ is also not so good with THD and phase. It always sound inferior to NO EQ.
I used to own the SONY TA-E2000ESD pre Amp. with a 91 band parametric EQ, with precision Q and amp (0.1dB +/-). It always sounded more natural without it, than with! I think that EQ never been better than that, and still...Thanks, but no thanks.
While it is a fair point it paints a darker picture than reality:That's relevant .
Any technical guy can fire back?
So almost every Hifiman that came AFTER the HE-6 is crappier stuff???? I bet on it!!!!This is a review and detailed measurements of the Hifiman HE-6 open-back, Planar Magnetic Headphone. It was kindly loaned to me by a member. There are different versions of this headphone in the wild. This is the "4-screw" version. The HE-6 has been discontinued. When available, it cost US $1,300.
The HE-6 has a serious look to it and beefy metal parts:
I think the wiring provided are aftermarket.
The large cups allowed it to instantly fit on my head with excellent comfort despite its above average weight.
The cup is round and its inside diameter is 60 millimeters. The depth is 18 millimeters.
Note: The measurements you are about to see are preformed using standardized GRAS 45CA headphone measurement fixture. Headphone measurements require more interpretation than speaker tests and have more of a requirement for subjective testing as a result. In addition, comparison of measurements between different people performing it using different configurations requires fair bit of skill. So don't look for matching results. Focus on high level picture. Listening tests are performed using RME ADI-2 DAC and its headphone output.
Mounting the headphone on my test fixture was challenging, resulting in quite a lot of variation between channels and overall response. I optimized this as best as I could but like there are some error in low frequencies.
Hifiman HE-6 Measurements
Before I show the measurement let me state that this was the easiest headphone to measure by far. I just put it on my test rig and it instantly registered equal levels in both cups. And furthermore, the level barely changed when I switched to a low frequency of 80 Hz. It was a joy in this regard!
Let's start with frequency response of HE-6 and comparison to our preference target to figure out tonality of the headphone:
Now you see what I meant by ease of measurements. See how the response is ruler flat and matching in both cups from 20 Hz to almost 1.5 kHz! I have never seen such precision before. Yes, our preferred response asks for more bass but this is a great baseline to have instead of drooping, or jagged response. Someone had a target of flat response there and got it! Beyond 1 kHz, we have some shortfall from target followed by excessive peaking and exaggerated highs. Neither is very extreme though:
Check out the distortion levels:
At 94 and 104 dB, there is essentially no distortion from 20 Hz to 10 kHz! 114 dBSPL brings out some unhappiness between 1 and 2 kHz. We can see that there must be multiple sound sources from the group delay:
Low frequency response though is textbook accurate with that sloping down graph. Again, I don't recall seeing another headphone that clean in that region.
Back to distortion, the HE-6 passes my 40 dBSPL threshold with flying colors:
The HE-6 has a reputation for being very inefficient, needing ton of power and we can see that in my testing:
It is in a class by itself there.
Typical of planar magnetic transducers, impedance is flat and low:
Hifiman HE-6 Listening Tests
I remember testing the HE-6 a couple of weeks ago for another purpose and saying, "hey, this is not bad!" Same impression held this time around. The sound is very clean with just a bit of high frequency exaggeration. What bass there is, is good enough baseline that you could live with. Still, I went after its response to matching to our preference better and the sound improved by a good notch or two:
I arbitrary dialed in that sub-bass EQ. It worked well enough to bring out that region without changing the overall impression of bass or making the headphone boomy. I put in a shelving filter to pull the highs down and that worked well. I think brought down the resonance around 4.3 kHz and compensated with pulling up the 2 kHz.
Once there, the transformation was impressive. Spatial effects were reasonable before but now were incredibly satisfying. It felt like you had your head inside a medium sized dull house with an orchestra playing! I wish I still had the Sennheiser HD800S with me to compare. From memory though, I think the HE-6 is close if not the same as its magical response in this regard. I am assuming the large cups and spacing from the ear is responsible for this open sound.
With equalization, I really had no other wishes for this headphone. It was comfortable and produced incredible fidelity. Everything was there from clean bass to detail and resolution. And oh, I was driving it with Topping A90 which could drive it quite loud on high gain. I also tested it on RME ADI-2 DAC V2 and it too managed to drive it. So no, you don't need a power (speaker) amplifier to drive it. High performance amplifiers I have been recommending can mange it.
I liked the sound of HE-6 so much that while working on the review, I was playing my selection of music with it and constantly saying, "wow, that sounds good!"
It is a shame this headphone is discontinued and was expensive to boot. Objectively the performance is quite good with distortion being a stand-out in addition to good amount of bass out of box. With four filters, the sound is transformed not only tonally, but also from imagine/spatial qualities, differentiating from other headphones.
I am going to put the HE-6 four-screw version on my recommended list. With EQ, it lands in my "highly recommended" bucket. Will be sad to let this go.
FYI, I have asked the owner to chime in and explain exactly what it is that I tested.He also lent me some other mods but I have not tried to assess them.
Well, I'm impressed with that headphone, especially the lack of distortion, but also the frequency response is not too jagged which seems to be a common pitfall with planar headphones. I'm also impressed that you relayed soundstage as being on par with HD800s, from your recollection of when you measured the HD800s. Do you think it would be worth it to purchase a few milestone headphones that display certain benchmark characteristics by which other headphones are compared....eg the HD800s for it's soundstage....that way you could flip between them and make more assured comparisons re soundstage & other listening impressions? You could purchase any notable benchmark headphones you come across in your growing arsenal of measurements. Afterall, for instance you said you didn't want to give this one back anyway!This is a review and detailed measurements of the Hifiman HE-6 open-back, Planar Magnetic Headphone. It was kindly loaned to me by a member. There are different versions of this headphone in the wild. This is the "4-screw" version. The HE-6 has been discontinued. When available, it cost US $1,300.
If we step out of fantasy land for a minute and click the first link in my signature, we will realize that typical speakers need no more than -3 dB preamp gain after EQ.That's relevant .
I bet the one which comes closest to HE-6 is ...... HE-560 !!!!!I have Ananda and Sundara so will be testing those soon.![]()
If the He-6se is out of consideration I would bet that it's actually the He-500. I have the He-500 in addition to this He-6 and find them to be very similar tonally. They also share the exact same magnet/cup structure with the difference being treatment on the diaphragm and aluminum traces instead of gold on the He-500.I bet the one which comes closest to HE-6 is ...... HE-560 !!!!!
Topping L30 can drive it at 12-1 o clock provided dac provides over 3volts. Sabaj d5 and 2qute can provide needed boost to l30.Hi
After this review which confirm my point of view of the HifiMan HE6 as an end game product, I no longer feel the scratch for the HD800 or anything. I did not also notice that the Atom could drive it to high volume. As a bona fide audiophile, I want headroom. I am not pleased with seeing the volume pot of the Atom near 3 o'clock to achieve "good"
HD800 is said to be very amp dependent and to escalate highhhhhhhh .........Hi
After this review which confirm my point of view of the HifiMan HE6 as an end game product, I no longer feel the scratch for the HD800 or anything. I did not also notice that the Atom could drive it to high volume. As a bona fide audiophile, I want headroom. I am not pleased with seeing the volume pot of the Atom near 3 o'clock to achieve "good" SPL.
Now I would like to see a review of the HE-6SE, the current version of this Classic and of the Sundaraa much hyped headphones.
Peace
What mechanism of amplification do you think would be responsible for that? It's a trick question.HD800 is said to be very amp dependent and to escalate highhhhhhhh .........
It's actually the other way around. Jaakko's EQ suggests the HE-6 was 10dB too bright (which it really isn't).
There are different HE6 around which sound different as well.
