There is a new HIFIMAN EF600 desktop DAC/Amp available for preorder: https://apos.audio/products/hifiman-ef600-desktop-dac-amp
The TLDR; is:
The unique design of the EF600 serves more than aesthetic purposes: it’s also a functional headphone stand. This space-saving feature allows you to stow your favorite pair of headphones directly on the EF600, eliminating the need for a separate headphone stand.
Unlike most DACs on the market, which use “Sigma” D/A chips from companies like ESS and AKM, the EF600 uses a “ladder” method to convert the digital signal from your computer into the analog signal you hear in your headphones. This approach uses an array of highly accurate resistors for tremendous musicality.
With Bluetooth, wirelessly connect a phone, laptop, tablet, or streamer to the EF600 and enjoy hi-def codecs like LDAC, which deliver lossless sound reproduction for audiophile-grade sonics.
Connect a turntable, CD or SACD player, and enjoy the EF600 as a high-performance headphone amplifier that’s fully compatible with most players via RCA and XLR.
Power will never be a problem with this DAC/Amp. Delivering 5 watts per channel @32Ω, the EF600 can drive the vast majority of low-efficiency planar headphones, including the HIFIMAN Susvara.
You’ll find four balanced outputs on the front panel: 6.35mm single-ended, 3.5mm single-ended, 4.4mm balanced, and XLR four-pin balanced.
The TLDR; is:
- Shaped like a headphone stand
- 2x R2R Ladder DAC
- It's an EF400 with a different shape, 2 DAC chips, and more input
- More inputs than the EF400s USB, (RCA, Bluetooth, XLR)
The world’s first DAC +Amp + Headphone stand
R2R Ladder DAC
HD Bluetooth
RCA + XLR inputs
Massive 5W per channel output power
Balanced + S/E outputs
Product highlights
- R2R ladder DAC
- 5 Watt per channel headphone amplifier
- Doubles as a headphone stand
- HD Bluetooth codecs including LDAC
- RCA + XLR inputs
- Multiple headphone outputs, including balanced and single-ended
Specs
- Outputs: 6.3mm single-ended, XLR four-pin balanced, dual (L/R) XLR three-pin full balanced line outputs
- Rear inputs: RCA, USB-B, and USB-C source connectors
- Signal-to-noise ratio: 118dB (weighted)
- Channel separation: 131+/-3dB
- THD+N (line out): 0.0014% (-8dB)
- Maximum power output: 5.12 Watts per channel @32 ohm balanced/1.8 Watts per channel @32 ohm
- Dimensions: 104mm/4” x 135mm/5 1/4” (top); 104mm/4” x 165mm/6 1/2” (bottom) ; 283mm/11”(height)
