solderdude
Audio-memory is poor.Need to update my last post because I've learned something new about unit variation.
I listened to two Arya Stealths, and even though one unit had only been used for a few hours, it made a difference.
Have you seen measurements that say it is so ?I never believed in burn-in, but it turns out it's not just a placebo.
Have you ruled out pad condition ?
Did you conclude this because you are sure you heard this (and assume audio memory is a good way to gauge this) ?
Drivers are shortly tested, I would not call this a burn-in but rather functional check or characterizing (for matching purposes)I also know that headphones undergo a burn-in phase at the factory, so is it possible that there could be a difference even right out of the box.
When would you say a unit is burnt-in enough ?To really confirm unit variation, I think you would need to compare two fully burned-in units
How many copies of the same model (in the same production run ?) would you feel is required to get an accurate feel of production spread ?
What percentage would be outliers ?
What about different production runs, months or even years apart, would show differences ?
