I'll receive my headphones tomorrow; they'll be used almost all time for gaming.
Connecting a PC with HDMI cable send video and audio to the AV receiver. The headphones are connected to the receiver's headphone output.
My questions are as follows:
Setting up the EQ. This receiver has simplified equalizer settings for headphones like the following adjustment frequency band
63 Hz / 125 Hz / 250 Hz / 500 Hz / 1 kHz / 2 kHz / 4 kHz / 8 kHz / 16 kHz
Adjust the level.
–20.0 dB – +6.0 dB (Default: 0.0 dB)
Only this settings.
- If I try adjusting the settings in the receiver maximum possible according to Amir's recommendations for Arya, will this significantly improve the sound quality of the headphones?
- Or will the headphone output on this receiver only produce mediocre sound quality? Would it be much better to connect a DAC like this iFi Zen DAC V3, Topping DX3 Pro+, SMSL C200PRO to the PC, output the headphones through the DAC, and adjust the EQ on the PC, how much would the sound quality improve in this case?
- Or will there be no significant difference in the sound quality of headphones between an AV receiver and a DAC like this?
Thank you.
Adjust the level.
Only this settings.
Thank you.
