Hello,
Aim: I want the best sounding mobile headphone setup possible. This could be high efficiency phones using my mobile to drive, or lower efficiency, but with a small light dongle (such as the E1DA)
I am currently using Superlux HD861 headphones with the official velour pads. System is now simply with my phone (xaoimi K20pro) since I found the android 'wavelet' app (100%recommended) and the preloaded Oratory's EQ profile for those headphones.
The sound is frankly shockingly good already, and a large part of me thinks I just cant see me beating them significantly as they are just so good with EQ! (£35 Inc pad is just silly for SQ like this.) But I would like to try and see just how good it can get.
I would like to find the best performing headphone that will run directly from a mobile phone or portable Bluetooth DAC/amp that I can for under £700.
The exact EQ profile will be adjusted to the Harman profile (with a couple of Db's of added bass as per my preference)
The strongest candidate I have found so far is the Hifiman Ananda. In many respects, I would have preferred the Sundara, partly as it costs half the amount of the Ananda. In terms of FR the current Sundara version is a better match to the Harman curve but it seams it would require an amp to get loud whereas the Ananda does not.
Rtings rate the Ananda as having a wider soundstage. The question is, is this entirely a function of the EQ profile, or is there more going on?
Sundara:
Ananda:
Arya
Given the now widespread availability of EQ, I feel the vast amount of reviews of headphones now don't offer the useful information they once did.
I know Solderdude suggests the data Rtings offer above is based on some testing (using the sennheiser HD800 as a benchmark) but is there any correlating evidence? Even Amir appears to describe soundstage as somewhat separate from FR (albeit impacted by it). Sean Olive appears to feel it is largely if not entirely a function of FR.
I'm sure many of us have tried EQing headphones to match the HD800s. It doesn't work. This leaves me following the Rtings data.
My other concern is decay:
Much of this is 45db down, but at 900hz it looks closer to only 20db down at what? 13us?
Any thoughts welcome!!
Sundara:
Ananda:
Arya
