HiFi Rose RD160 specifications
deltasigma
Hi folks,
Searching through the forum, it doesn't look like there's been any discussion of the new-ish HiFi Rose RD160 DAC. The unit is marketing a cost-no-object topology with a AK4191EQ doing initial delta-sigma conversion and then feeding into a AK4499EX for the actual D/A conversion, duplicated for a dual mono setup:
However, the posted specifications are surprising:
This seems to indicate a SINAD of 86dB or 94dB in the "regional version" (not sure what that is), neither of which seems like what you'd expect to see in a flagship $5k unit from an otherwise-reputable manufacturer. Am I misunderstanding something? Has anyone tested one of these units?
Their website has different SNR (132) and .0002 THD. Maybe these were early numbers.
The 132 dB SNR measurement on their USA page (here) is listed as A-weighted and not yet confirmed ("TBC"), whereas the 124dB measurement on their global page (here) appears unweighted. Still, those numbers are further apart than makes sense, as are the THD+N and THD numbers on those two pages. I sent them an e-mail 3 days ago inquiring about this but haven't yet heard back; I'll update the thread if they respond.
A $5K DAC with an 86-94dB SINAD? That’s not what you'd expect from a so-called flagship. Then their own website has different SNR and THD numbers, which makes it even weirder. Either these are early, inaccurate numbers, or there’s some funny business with how they're measuring.
I’ve tried the toppings and the smsls lauded here and to my ears they’re brittle and thin.
Pointless to say so, and I won’t argue back. I have an Eversolo a10 which measures within the gestalt of this website. I also have the RD160 and to my ears it’s far better. I won’t waste time with the audiophile words - space, depth. It’s just better and more like live music to me. I’ve also had the Tabaqui, the Dave, and MSB Premier and others lauded and ridiculed here.
So, I can handle the sarcastic replies and the observations about the magic of apple dongles. that’s ok. It’s beyond silly to argue about these things. I’m in it for the enjoyment of music.
The company confirmed in writing that 0.005% THD+N (86dB SINAD) is the correct measurement, and they have updated the USA product page which previously had an incorrect number.
Just ran across this while searching for distortion measurements. My cousin has Focal Sopra 3s and an Aesthetix Mimas integrated. We just did an A/B from the Lumin DAC to the Hifi Rose.
I was unaware of which was which as the electronics are located behind a wall. It was absolutely a night and day difference. I'm no longer in the all DACs sound the same camp. The Hifi Rose revealed alot more details. The vocals sounded much more realistic and the sound stage was huge with much more separation of sources.
He also has a really high end vinyl set up that somewhat rivaled the Lumin. Since setting up the RD160. He's having a hard time going back to vinyl.
I believed the hype about distortion measurements being a panacea indicator of DAC performance before. Now after seeing how poor the RD160 specs are. I'm not sure what to think.
There's a review of the RD160 in the current Stereophile issue:
The HiFi Rose RD160’s distortion signature primarily comprised the third and fifth harmonics (fig.14), but these were very low in level, lying at –99dB (0.001%) and –109dB (0.0003%) respectively. While other harmonics are present, these all lie at least 10dB lower in level. Fig.14 was taken into 100k ohms; when I repeated the spectral analysis into 600 ohms, the levels of all the harmonics increased by around 8dB but were still very low in absolute terms.
It looks that they confirm the high THD+N. Not what I've expected from a DAC based on top AKM chips.
