Hi! I am looking to buy a dongle or portable DAC to use with my IEMs and my headphones (Moondrop SSP, starfield, SeeAudio Yume, Sennheiser HD560s and PXC 550ii).
And I am not sure if I buy the Hidizs S9 (dongle option), or the Fiio Q3 (portable DAC option). The review suggests that the hidizs does not have perceptible distortion. And I was wondering if this feature can compensate the lack of power (compared to the fiio).
I hope I could get some advice here. I am kid of new on headphones and DACs. Thanks!
Fiio has its own battery so won't use up the one in your phone. But then it is a lot bigger and heavier. You need to decide what is more important.
I have the S9 which is great when I don't need a microphone for calls, for that I use the
FiiO BTR5 - which is quite a bit smaller than the FiiO Q3 - and the BTR5 has onboard battery power.
I've used the BTR5 for desktop and mobile use, both connected with USB to phone/PC and via Bluetooth - phone BT pairs with BTR5, IEM's plugged in to BTR5, and BTR5 internal microphone does a great job on calls - much better than inline mic on IEMs and TWS's.
The BTR5 has plenty of power for IEM's, and most of my headphones. My Beyerdynamic DT880 600ohm on SE max out the BTR5, but it is listenable. Balanced on the BTR5 puts out much more power so if you can use the 2.5mm jack and balanced headphone cables to get the most out of the BTR5.
The
FiiO BTR3k is even smaller and has its own onboard battery, but has less power output.
Both can be configured to run on battery only - or in other words turn off the parasitic power draw from USB power - which is needed on the iPhone and handy on other devices you don't want the BTR5/BTR3k to drain power.
I've got several BTR5's and they are all still working, same goes for the BTR3k - bonus is the BTR3k can act as USB-C DAC for Nintendo Switch - the BTR3k is also supposed to work with the PS4 (PS5?), but I haven't tried it personally.
There are a lot of new choices out there for small battery onboard portable external DAC/AMPs, look around, or start with the
BTR5 /
BTR3k as they are the cheapest with onboard battery I have hands-on experience with.
Here is Hifigo's Portable DAC/AMP's listed by Newest first:
https://hifigo.com/collections/portable-1
...anyone have other similar form-factor / function units in mind?
As a word to the wise, if you have problems with these small units - they have limited physical interfaces - so you need to use the app (if the device has one), and even then things are precise - like if you disable the USB Power - you will run out of power and "brick" the unit, but all you have to do is to plug in USB power and leave it charge for a few minutes, then after you power up re-enable powering from USB to finish charging.
I have used the BTR5 with USB power enabled with a desktop PC for endless hours of fun, and when portable if I needed to I disabled the BTR5 option to power from USB and when the BTR5 ran out of power I simply swapped in another 100% charged BTR5 and keep going, putting the 0% charge BTR5 away to re-charge later.
The reason I mention this is I was reading Amazon reviews and "all" of the negative reviews were PEBCAK Errors - Problem Exists Between Chair and Keyboard, like complaining about "bricking" their BTR5. Always remember we aren't infallible, check upstairs for the source of the problem before looking externally for the source of the problem.
