Hidizs S9 Pro vs Purifi power amp + L-pad box for DUNU Arashi — worth building?
jbo3320
Hi all,
I recently bought a DUNU Arashi (planar, 26Ω, 97 dB/mW ≈ 113 dB/Vrms per spec) and I'm considering building a small L-pad / switch box so I can drive it from my speaker power amp. Before I commit, I'd like a sanity check on the design and on whether I should expect any audible difference versus the dongle I already own.
Gear I already own
- Source A (current): Hidizs S9 Pro dongle, balanced out
- Source B (planned): Topping D90LE (XLR out, preamp mode) → VTV stereo amp with Purifi 1ET6525SA modules (input buffer jumpered to unity gain, so overall gain ≈ 12.3 dB) → L-pad box → Arashi (balanced 4-pin XLR)
- The same amp normally drives KEF R3s, so the box would switch between speakers and headphones.
Planned box (per channel, L and R identical, returns kept separate)
Code:
Purifi OUT+ ──[Rs 27Ω, 25W]──┬────────── HP +
                       [Rp 2.7Ω, 5W]
Purifi OUT− ─────────────────┴────────── HP −
XLR4: 1 = L+, 2 = L−, 3 = R+, 4 = R−
Switch: per-channel DPDT (both + and −), break-before-make
        pos A → KEF R3, pos B → L-pad → headphone
OUT− not tied to chassis or to the other channel
(Purifi datasheet says not to route OUT− to GND elsewhere)
My numbers (with Arashi at 26Ω)
- Attenuation: (2.7∥26) / (27 + 2.7∥26) ≈ −21.6 dB
- Source impedance seen by the headphone: 27∥2.7 ≈ 2.45Ω
- Load seen by the amp: ≈ 29.5Ω
- Max at headphone (D90LE full scale): 1.44 V (4V mode) / 1.78 V (5V mode) → ≈116 / 118 dB SPL
- Noise at headphone: D90LE ~1.1 µV × 4.1 and Purifi ~6.6 µV(A), then × 0.083 → ≈0.7 µV → about −10 dB SPL
- Dissipation at full-scale sine: Rs ≈ 9–14 W (hence 25W aluminum-clad), Rp ≈ 1.2 W
S9 Pro, for comparison
- Member measurements here (unloaded): 4.25 Vrms max balanced, ~105 dB SINAD, noise −122.7 dB(A)
https://www.audiosciencereview.com/.../hidizs-s9-pro-measurements-dac-dongle.34082/
- Spec is 200 mW @ 32Ω (≈2.5 V), which suggests it may be current-limited (~80 mA) under load. Not verified, since the review had no load board.
- I plan to check this myself: 27Ω dummy load + DMM, 1 kHz 0 dBFS, stepping the volume up to see where the voltage stops rising.
How I listen
With the D90LE at around −28 dB, peaks are roughly 88–90 dB SPL (~70 mV at the headphone). I also run PEQ (AutoEQ to a 5128 DF target, about −3.8 dB preamp).
Questions
1. At these listening levels, should I expect any audible difference between the S9 Pro and the Purifi + L-pad, level-matched and blind? My guess is no, apart from current headroom on loud bass-heavy peaks, but I'd like to hear from people with more experience.
2. Any flaws in the box design? In particular the OUT− handling with the Purifi modules, the switching, and whether I should add a fuse/polyfuse for protection.
3. Given that I usually sit at −28 dB on the DAC, would you change the resistor values (e.g. 47Ω/2.7Ω for a lower max-SPL ceiling)? Or keep 27/2.7 for headroom with quiet classical masters and my HE400se (~107 dB/V)?
4. Overall: is this worth building, or should I just keep using the dongle?
Thanks!
I once built a speaker output to headphone adapter using an l-pad, but felt it acted as a tone control depending on the l-pad's setting. This was with a Dyna SCA35 tube integrated amp which lacked headphone output. I never bothered to repeat the experiment.
This is plain stupid, no two ways about it.
Your headphone is as far removed from the category of headphones for which a Speaker Amp might make sense, as they come.
It's stock Prius with a huge wing levels of stupid.
Isn't it the same principle as the Hifiman headphone adapter? I was under impression that rather than buying an expensive headphone amps, if I have a power amp already, I could save some money by doing this.
