I may be a bit of help here : not suited for anything over 150 ohms if you (moderate to heavy) bass shelf EQ it. Planars needing EQ, hard no. I think (emphasis on "think") it distort at the last physical volume step, so I keep it at the penult... (f.ck, is this a thing in English ?) - the step before. I use a TRRS to TRS 3.5 adapter to force high gain. Usefull with tricky 560s (tricky as it does not commute high gain by itself). High gain feel (emphasis on "feel") less precise than low gain. Still one of the best investment I made (S8) despite the drawbacks (volume, gain, etc.). Not the blackest background, not he most detailed, not he better latteral soundstage, not the deepest, but the most consistent on everything. I'm musician, nothing feels wrong on it. And f.cking good transients. None of the dongles I own beats it in that domain. Perfect match with EQed AKG 371. You get a killer combo for a reasonably decent amount of monney. Thanks ASR
[EDIT] If you're not happy with
@L5730 answer (why should you ?), let me know.
