"Hidizs Sonate HD DAC Cable 1st&2nd Windows Driver Upgrade"
They share the same ASIO driver
The Cirrus USB bridge is the deciding factor here. Ivan also tried to implement it in his 9038S and D, but the Cirrus spokesman in China basically told him to pay him thousands or he could f*ck right off.If this is accurate, the Meizu Pro draws less power, despite additional op amps that the Hidizs S8 doesn't have. I'm not an engineer, so not sure how additional op amps affect current draw.
I did not find any driver dll or setup in this zip file, only a setup with some firmware update instructions.
I have sent an email to Hidizs anyway, let's see.
If you are looking for an ASIO driver that supports the S8, try this:
http://www.tempotec.com.cn/en/3-Support/index.htm
At the bottom, download this:
Using that driver and ASIO is the only way I can get the Sonata HD Pro to play non 44.1/16 files in Foobar.
Thank you very much!
The driver installs this Tempotec control panel where it displays all the ASIO information. Now JRiver + ASIO using upsampling to DSD256 native works fine. Had to re-apply the Equalizer APO settings to this new "device" (driver) and a reboot and it is fine.
I would guess the upper part shows how Windows is set-up in Control Panel and indeed I set it that way, and the bottom part only works when using ASIO playback, and DSD256 and 100 ms are the settings I use with JRiver, and it says 24 bits because it must be padding with zeroes to fill the 32 bit packets. JRiver says the same.
The top part of the TempoTec control panel controls the Windows audio device's Properties - Advanced - Standard Format dropdown. I set it to maximum (384/32).
On foobar2000 using the TempoTec drivers I managed to get it working 24/96 file output to WASAPI push output data format 32 bit.
The tempotec sonata HD Pro is the same internally and functionally as the s8. After that, take your pickHello, Friends.
(first thing first, sorry for my bad English).
Which DAC/Amplifier is the best option for a KZ KSX:
- Meizu DAC Pro (U$38) - https://pt.aliexpress.com/item/4000152039684.html?spm=a2g0o.cart.0.0.43303c00FuH7lS&mp=1
- Hidizs S8 (U$80) - https://pt.aliexpress.com/item/4000560966739.html?spm=a2g0o.cart.0.0.43303c00FuH7lS&mp=1
- Hidizs Sonata S3 (U$45) - https://pt.aliexpress.com/item/4000548563490.html?spm=a2g0o.cart.0.0.43303c00FuH7lS&mp=1
- Tempotec Sonata HD Pro (U$38) - https://pt.aliexpress.com/item/4000628268773.html?spm=a2g0o.cart.0.0.43303c00FuH7lS&mp=1
If the Hidizs S8 sound quality is really batter than the others I do not care to pay a little bit more.
Best Regards
Search a few pages back for measurements comparing both, and you will see they measure the same.All the internal components are EXACTLY the same? or just the DAC chip is the same?
The graphs and the sound quality are EXACTLY the same too?
*Sorry for the beginner question, but I'm not understanding some technical specifications in the previous comments
This is my understanding from earlier posts on this thread and elsewhere. Identical electrically speaking. Same additional cables etc in the box too.All the internal components are EXACTLY the same? or just the DAC chip is the same?
Same PCB with everything on it.All the internal components are EXACTLY the same? or just the DAC chip is the same?
