Try with something else, primarily with HiBy app on iOS/Android & yes it's Sonata all right.Hidizs S8 - DSD 256 doesn't support.
anyway for me all four are bad products; Meizus lacking volume control and TempoTec's having to big volume steps, neither of them having proper drivers or suport.
Well you can try the TempoTec Sonata iDSD regarding me, it's not a dongle nor ultra portable as it's a size of smaller smartphone from the past. It's a ES9018K2M + Sabre9601k combo. I wouldn't exactly recommend it's bigger full balanced brother Sonata iDSD Plus thanks to various production defects (which are supposedly resolved but then again). They have separate USB power input lines and LiPo batteries while volume steps are deacent (could still be to big with very efficient lo impedance EMI's 16 Ohm's or less). First one is ideal for 32~40 Ohm's EMI's while Plus goes twice that much with balanced line & 40~64 Ohm's will unbalanced. They actually can drive most cans with higher impedance than I mentioned (64,128 Ohm's) but that's what is optimal to be driven with them. On the down side the USB cables for mobile use aren't exactly great. I can recommend their (TempoTec) Serenade iDSD as a desktop part that's not very hard to transport which will sound rather polite & can drive big can's (up to 200~250 Ohm's) while it's not bad either for EMI's. It's AK4490 DAC and JRC45580dd should be OP amplifier but it's expandable anyway. It has analogue volume control, and cetera. Also like it's design as it can also be used as headphone stand. But now it's not exactly the best time for buying those, they had discounted prices for Chinese new year and will probably have it again for spring festival & besides you have to take into consideration & current epidemiology situation for anything made or shipped from China or at least rub & scrub it when it arrives with some disinfectant.I think I've seen you mention this in other threads? Just curious, what do you recommend in the dongle/highly portable space? In my room I replaced my Benchmark DAC2 with a 9038S, can't even tell the difference, and with these low cost dongles I don't mind buying a few to experiment with.
Best regards.
I have Sonata iDSD and while it's not exactly elegant solution (as it's the size of Nokia N808) but I am pretty much satisfied with it (on the go at least) tend to use it over the DSD line as much as I can. It first in the most pockets (including inter jacket one & top shirt one) combined with smartphone but you will notice it all right. Currently I use those "magic" synthetic tapes to stick it up to the phone (it works & looks better than ribbons while not interfering with display of the phone). Worst down side of Sonata is that you will have to buy a decent USB C cable for it (that is if you already don't have one, I ended buying Shanling L2). Unfortunately no i don't really know any dongle alike tiny one which I could truly recommend. That's why it whose so much fuss around hire about Meizus & S8/Sonata HD Pro in the first place as they ware close to that (at least measured performance wise) but they lack a lot in other fronts. It seems cutting corners won't ever get us there so it needs separate autended power in USB line or separate power line & battery (which ain't gonna ever fit in tiny dongle design but it's cheaper than proper pured power line in).Thanks! Sorry, I should've been more specific, I typically use these devices on-the-go (biking, lifting weights, etc) so the Serenade wouldn't work. The Sonata could work, but in the past I had an Oppo HA2 and it was really inconvenient. That's what fascinates me about these little "thumb drive" dongles - what cost me $1700 3 years ago (DAC2) now costs $90 shipped halfway across the world and I don't even notice they're in my pocket! Do you have any favorites in that format?
Edit:
@tifune in your case I would consider a nice mid range DAP for your typical use case at least & in that category not much thing's beat Shanling M2X for now (at least not to my knowledge). For me as I insisted on real time converting of everything on the go to DSD, DAP's are a no go (as even flagship new ones don't have enough CPU power for that task).
P's what I can recommend you is perfect earbuds (at least for me) for workouts and casual listening on the go. The Creative Aurvana Air & if you like them try to snatch them on discount I bought mine almost two years ago on Amazon prime day for 45£.
Best regards.
Quick test for you:I recently tried using the Apple Lightning to 3.5 mm adapter with my iPhone Xr with these changes:
- Airplane mode (but Wifi On)
- Disabled Face ID, Location, Vibration, Motion, Ringer, Tape to Wake
- Low Power Mode selected
I can hear some difference in the sound. Sounds less bright. Can @amirm or @IVX or someone else please measure whether such changes on phones lead to measurable differences with dongles like the Apple one, Hidizs S8 and Meizu Pro which are sensitive to noise on USB. These dongles are meant to be connected to phones and hence, we need more measurements under those conditions. Please, please !
One "weird" thing though, I've tried a few shorter usb to micro usb cables I had laying around, but only the one that comes with the s8 works. The other cables won't let it show up on my mac.
That seems to be the case no matter which OS it's used with. From the Hidizs website:I'm afraid this was a user error on my side. Apparently the S8 only shows up on a Mac when you plug a pair of headphones in. The other cables also work.
Please note: you have to plug-in the headphone into the S8 first, then connect S8 to the audio devices, otherwise the S8 cannot be recognized by audio devices.
Read a post on here somewhere (Think on Meizu review thread) enable USB debugging in dev options. Member had same reboot issue on an Android device.Usage update: My Galaxy Note 10 reboots when I disconnect the Hidizs S8. Happened twice already. Will observe some more and report back.
